![]() | Home > Maintenance & Mods (L322) > L322 Side Steps question |
Rapiscan Member Since: 28 Apr 2018 Location: North Lincolnshire Posts: 182 ![]() ![]() ![]() |
Our cars should have been made to lower upon demand much further than they do, this would have negated the need for unsightly fixed sidesteps or indeed expensive complex deployable ones, poor forward thinking by Land Rover. |
Range Rover L322 Member Since: 03 Sep 2019 Location: South West Posts: 331 ![]() ![]() |
This chap is really helpful... to remove that panel pull out the bottom then there's an 8mm hex head self tapping screw pointing upwards at the front side. Hard to get to, this video explains all.
Rog21 Member Since: 09 Nov 2018 Location: Havant Posts: 62 ![]() ![]() ![]() |
took my side steps off yesterday as they were collapsing, four of the small 10mm bolts broke off so if I want to fit new steps I have to find a way of drilling out holes and retapping. No space due to air suspension tank.
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4319 ![]() ![]() ![]() |
"Also how do the sill protectors come off, do I just take out plastic clips at bottom and pull off. Thought I would check all areas for rust just in case."
Rog21. One of my 13mm bolts sheared. I don't have welding gear at home so I took it to a local welder who welded a nut onto the stub and got it out. That should work for you as it doesn't require drill space or re-tapping.
If only it was that easy. The 13mm broke leaving no exposed thread, that's fine as I can drill out.
Nick591 Member Since: 04 May 2017 Location: Seaton Dalaval Posts: 193 ![]() ![]() |
I had to drill out and retap the two front 10mm bolts on each side. I used a right angle drill. On the air tank side I reasoned that if the holes weren't exactly square to the chassis a) it wouldn't affect the mechanical strength or function of the fixing, and b) it would make retapping the thread a lot easier. So it proved. My biggest problem was blunt drill bits. Must get a drill sharpener!
Unless you need steps to get in n out, why bother with em? They are ugly dirt collectors inho. Despite people's best efforts they WILL corrode, they all seem to be made of cheap mild steel, dunno if deployable ones are better regarding corrosion? Considering the price I'd hope so, I've no regrets about scrapping my old steps, Im fortunate i can get in and out without dragging the seat bolster excessively. 2008 L322 Vogue 3.6 TDV8 in Java Black with parchment and Navy interior. 125000mls.
Tim Member Since: 24 Sep 2020 Location: Carrickfergus Posts: 4 ![]() ![]() |
Do Sport side steps fit? |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7865 ![]() ![]() ![]() |
I wouldn’t think so. Platform of the car is different.
Ta |
Mounting points are completely different - I checked with my mate's Disco 3, which (I am fairly sure) shares the same platform |
garyRR Member Since: 13 Mar 2021 Location: Hampshire Posts: 1480 ![]() ![]() |
Yes aftermarket are basically the same however, when I got a pair on my old RR, there were a few quality check issues from the factory - one of the side steps was warped and hung slightly low. And, the bolt holes didn't exactly like up and were around 3mm off in places - not much but enough of a pain to have had to re-drill the holes larger in order for the bolts to fit the chassis.
jackie-o Member Since: 15 Jun 2018 Location: Sweden Posts: 226 ![]() ![]() |
@Range Rover L322, do you know if its possible to fit your after market versions into the original front mud flaps?
