Home > Technical (L322) > Restricted perfomance
killa
United Kingdom 2010 Range Rover Autobiography TDV8 Bonatti Grey
Restricted perfomance flicking on and off on dash mainly when cold.
Only stays on for a second car seems to drive ok.
I don't have a code reader yet so no idea what to check.
2010 autobiography 3.6 .
Post #526566 30th Aug 2019 4:26pm
Randomly or when accelerating ?
Top intercooler hoses are a common cause on the 3.6
https://www.fullfatrr.com/forum/topic26843.html
Post #526574 30th Aug 2019 5:15pm
killa
Flashes briefly on start up and random after that.
Sometimes on acceleration sometimes when idling
Post #526579 30th Aug 2019 6:11pm
killa
Thanks for that link will be towing tintent next week so will check hoses.
Post #526580 30th Aug 2019 6:15pm
kbald
Have you had the codes read at.all? Would be a good place to start but a failing battery or alternator can give a lot of false codes. Current 2007 TDV8 Vogue Buckingham Blue
Post #526607 30th Aug 2019 10:13pm
killa
Got codes read today.
Egr valve circuit C.
Post #527063 4th Sep 2019 4:38pm
kbald
What was the actual code that it threw up? Current 2007 TDV8 Vogue Buckingham Blue
Post #527065 4th Sep 2019 4:55pm
killa
That's all I was told
Post #527072 4th Sep 2019 5:22pm
kbald
There's not much to go on there unfortunately without the full code. It would normally be p followed some numbers and letters. This helps pin point where the issue lies. Current 2007 TDV8 Vogue Buckingham Blue
Post #527076 4th Sep 2019 5:34pm
Andy
Can anyone confirm that when Restricted Performance appears, it’s accompanied by further messages like stability control, forward alert, abs etc. I read on a Facebook group that if these further messages appear it’s not an engine related fault. One owner said it could be a battery problem. For info, mine doesn’t have an AGM battery and it’s a 2010 model. 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded
Post #527111 4th Sep 2019 9:26pm
kbald
Mine is a non tft dash but came up engine system fault then special programs off (all the off road suspension stuff) so similar and this was a cracked inlet manifold. This threw up a p023d code. An alternator failing would throw up lots of codes as well like suspension etc so could be many things. Current 2007 TDV8 Vogue Buckingham Blue
Post #527121 5th Sep 2019 7:45am
kbald
If you paid for the codes read I would go back and ask them for the rest of the info.
What was suggested they do to resolve the issue? Current 2007 TDV8 Vogue Buckingham Blue
Post #527123 5th Sep 2019 7:47am
cass
Andy
I think you’re getting lots of poor info from Facebook. I don’t think that randomly changing things like the battery is going to be helpful.
What codes are are being recorded?
Personally I would return it to standard as this can only help your fault finding by removing an unknown variable then try some logical fault finding rather than hoping to get lucky with Facebook guesses
Good luck
Post #527179 5th Sep 2019 8:06pm
Andy
Here is the fault code:
Post #527181 5th Sep 2019 8:35pm
Nick591
That is a probably a leak in the high pressure (i.e. after the turbo) side of the drivers side cylinder bank. Check first for a split in the top left-hand hose as you look into the engine compartment. Previously a 2008MY Tonga Green Vogue SE 3.6 TDV8
Post #527184 5th Sep 2019 9:02pm
