Home > Technical (L322) > Restricted perfomance |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7911 |
Randomly or when accelerating ?
30th Aug 2019 6:15pm |
killa Member Since: 23 May 2019 Location: birmingham Posts: 20 |
Flashes briefly on start up and random after that.
30th Aug 2019 7:11pm |
Thanks for that link will be towing tintent next week so will check hoses. |
30th Aug 2019 7:15pm |
kbald Member Since: 17 Aug 2015 Location: Leeds Posts: 490 |
Have you had the codes read at.all? Would be a good place to start but a failing battery or alternator can give a lot of false codes. Current 2007 TDV8 Vogue Buckingham Blue |
30th Aug 2019 11:13pm |
Got codes read today.
4th Sep 2019 5:38pm |
What was the actual code that it threw up? Current 2007 TDV8 Vogue Buckingham Blue |
4th Sep 2019 5:55pm |
That's all I was told |
4th Sep 2019 6:22pm |
There's not much to go on there unfortunately without the full code. It would normally be p followed some numbers and letters. This helps pin point where the issue lies. Current 2007 TDV8 Vogue Buckingham Blue |
4th Sep 2019 6:34pm |
Andy Member Since: 24 Feb 2009 Location: Shropshire Posts: 2938 |
Can anyone confirm that when Restricted Performance appears, it’s accompanied by further messages like stability control, forward alert, abs etc. I read on a Facebook group that if these further messages appear it’s not an engine related fault. One owner said it could be a battery problem. For info, mine doesn’t have an AGM battery and it’s a 2010 model. 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded |
4th Sep 2019 10:26pm |
Mine is a non tft dash but came up engine system fault then special programs off (all the off road suspension stuff) so similar and this was a cracked inlet manifold. This threw up a p023d code. An alternator failing would throw up lots of codes as well like suspension etc so could be many things. Current 2007 TDV8 Vogue Buckingham Blue |
5th Sep 2019 8:45am |
If you paid for the codes read I would go back and ask them for the rest of the info. What was suggested they do to resolve the issue? Current 2007 TDV8 Vogue Buckingham Blue |
5th Sep 2019 8:47am |
cass Member Since: 12 Oct 2011 Location: northumberland Posts: 726 |
Andy
5th Sep 2019 9:06pm |
Here is the fault code:
5th Sep 2019 9:35pm |
Nick591 Member Since: 04 May 2017 Location: Seaton Dalaval Posts: 193 |
That is a probably a leak in the high pressure (i.e. after the turbo) side of the drivers side cylinder bank. Check first for a split in the top left-hand hose as you look into the engine compartment. Previously a 2008MY Tonga Green Vogue SE 3.6 TDV8 |
5th Sep 2019 10:02pm |
