Home > Technical (L322) > TDV8 whistle |
Grofus Member Since: 24 Mar 2017 Location: Co Clare Posts: 577 |
Some inlet manifolds have cracked causing a whistle.
31st Jul 2019 12:26am |
Bogi 6357 Member Since: 28 Jul 2019 Location: Scottish Borders Posts: 54 |
Thanks for the reply , will check the inlet manifolds , hopefully it is that . |
31st Jul 2019 9:12am |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4300 |
Failing that, there is an excellent independent in Dundee.....DiscoMikey on most forums and MMP Land Rover on Facebook. Very highly regarded Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
31st Jul 2019 11:37am |
Yes very Good advice , DM gave me some good pointers when I had the Disco 3
31st Jul 2019 2:07pm |
cass Member Since: 12 Oct 2011 Location: northumberland Posts: 730 |
31st Jul 2019 5:38pm |
Brilliant thanks ,I’m going to go have a look
31st Jul 2019 5:52pm |
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1749 |
31st Jul 2019 8:51pm |
Thanks for the reply Mikey
1st Aug 2019 9:49am |
RH is much easier than LH
1st Aug 2019 4:02pm |
Cheers Mikey I’ve got your number , I will give you a bell about booking in once I’ve convinced myself it’s that 😂
1st Aug 2019 6:19pm |
Give me as much notice as you can. We're booking for 10th September as it is |
1st Aug 2019 6:54pm |
Ahh well the inevitable happened 😂 one or both of my turbos have popped , symptoms cruising along and devoted to accelerate road was quiet and a big long straight section , lose all power and coasted to a stop no noticeable smoke from rear either
2nd Aug 2019 7:22am |
j_rov Member Since: 10 Jan 2017 Location: Warwickshire Posts: 386 |
Doesnt sound like a turbo issue.
2nd Aug 2019 1:33pm |
I will get the soapy water check done this weekend , I’ve got some methacrylate structural adhesive requisitioned from work
2nd Aug 2019 6:31pm |
