Home > Technical (L322) > TDV8 whistle
Page 1 of 3 123>
Bogi 6357
TDV8 whistle
Experiencing a few issues in my 3rd day or Vogue L322 ownership 😂 suspension compresser issues and tail light which I have resolved myself with input and researching on this great site
However I’m not sure I can fix this one !
I have a whistle from about 1500rpm to 2500 which I can hear under acceleration
After some pointers ,could this be a boost leak and how can I check it (hope it is )
I’ve had a look at the 2 top intercooler hoses and also took the engine cover off
Looked at the 2 left and right short rubber pipes all seem fine , I’ve checked around the egr also , I can hear a faint whistle when the engine is revved in park , but I don’t get the full on whistle untill under load , would an exhaust gasket leak cause a whistle ,
I haven’t got any restricted performance messages or Eml lights or any smoke or smells of any kind if that helps with diagnoses and mpg seems very good almost too good ? very little on the site regarding whistle ! I’m praying that it isn’t turbos on there way out , any help would be greatly appreciated , garage I go to is great but a 2 week waiting list
Cheers Ian
Post #523372 30th Jul 2019 10:54pm
Grofus
Ireland 2007 Range Rover Vogue TDV8 Zermatt Silver
Some inlet manifolds have cracked causing a whistle.
They are plastic and some members have repaired them with epoxy or JB Weld.
Test for leaks and splits with a smoke machine to help track it down
Good luck with it 2007 Vogue TDV8 in Zermatt Silver with Charcoal
Post #523379 31st Jul 2019 1:26am
Bogi 6357
Thanks for the reply , will check the inlet manifolds , hopefully it is that .
Post #523397 31st Jul 2019 10:12am
DrRob
Failing that, there is an excellent independent in Dundee.....DiscoMikey on most forums and MMP Land Rover on Facebook. Very highly regarded Thumbs Up Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #523405 31st Jul 2019 12:37pm
Bogi 6357
Yes very Good advice , DM gave me some good pointers when I had the Disco 3
I’ve seen that he has done numerous warped exhaust manifolds also for TDV8 if that’s what this turns out to be.
Post #523421 31st Jul 2019 3:07pm
cass
Check the under side of the engine cover for oily/Sooty marks - mine provided a great clue as to where the leak on the manifold was.
Post #523441 31st Jul 2019 6:38pm
Bogi 6357
Brilliant thanks ,I’m going to go have a look
See if I can see any sootyness , I looked around the pipe work I could see last night and cleaned everything up mainly just intercooler hoses though there seemed to be a lot of dirt kind of oily grime on the left hand side one where it connects to the intercooler ,but couldn’t find a split so tightened it up a bit more and cleaned away the gunk , I’ve got an egr blanking kit coming tomorrow so I’m going to fit that also not sure if faulty egr can whistle ,
does the intake manifold crack in the same place is it a common fault , I will take some photos if I can find any damage to it , thanks for the heads up with the engine cover contamination I didn’t notice it last night but it was half light with an iPhone torch when I was messing about with it 👍
Post #523444 31st Jul 2019 6:52pm
Mikey
Inlet manifolds do crack, and cause oily deposits on the soundproofing
Usually, it will cause an ESF warning, and drop into restricted performance etc with a split manifold Thumbs Up
Post #523462 31st Jul 2019 9:51pm
Bogi 6357
Thanks for the reply Mikey
Weather was rough last night so didn’t get a chance for a proper look , I’m going to try a bubble test with a bit of soapy water on the seams , I don’t have any restricted performance codes at moment or smoke of any kind just a whistle that’s matured since I’ve picked the vehicle up 5 th day of ownership ,but I haven’t put it under any flat out or wide open throttle situations yet as was frightened it might crap it’s turbos , hopefully it is the intake manifold crack and not broken nuts or studs and warped exhaust manifold , if it is the exhaust manifolds is that something that I could travel up to Dundee from Berwick and have you do within the day once booked in ? Or is it a mammoth job time consuming.
Cheers
Ian
Post #523489 1st Aug 2019 10:49am
Mikey
RH is much easier than LH
Id allow a few days for workshop scheduling, and any unforseen works that may crop up
I do have a courtesy car available, for the duration Thumbs Up
Post #523525 1st Aug 2019 5:02pm
Bogi 6357
Cheers Mikey I’ve got your number , I will give you a bell about booking in once I’ve convinced myself it’s that 😂
I’m gonna have a good look over the weekend , thanks for the reply
Post #523533 1st Aug 2019 7:19pm
Mikey
Give me as much notice as you can. We're booking for 10th September as it is Shocked
Post #523536 1st Aug 2019 7:54pm
Bogi 6357
Ahh well the inevitable happened 😂 one or both of my turbos have popped , symptoms cruising along and devoted to accelerate road was quiet and a big long straight section , lose all power and coasted to a stop no noticeable smoke from rear either
Waiting to be recovered 😢🤬( Censored )
Post #523552 2nd Aug 2019 8:22am
j_rov
Doesnt sound like a turbo issue.
Have you looked for the inlet issue. Its more and more common as they get over 10 years old.
I think the plastics are drying out.
I have a few tips to fix if you want to pm me once checked with soapy water. __
2018 L405 3.0 TDV6 Vogue SE Fuji White
2000 4.6 V8 HSE Oxford Blue
1994 3.9 V8 Vogue Ardennes Green - resto project
Land Rover History:
2010 3.6 TDV8 Autobiography Stornoway Grey
2001 Discovery 2 TD5 GS
1999 Discovery 2 V8i XS
1994 Discovery 300Tdi
1993 Discovery 200Tdi
1989 Range Rover Vogue SE 3.5EFi
1976 Series 3 2.25
1977 Range Rover 2 door 3.5 Carb
Post #523606 2nd Aug 2019 2:33pm
Bogi 6357
I will get the soapy water check done this weekend , I’ve got some methacrylate structural adhesive requisitioned from work
Which I’ve used to good effect on various things never an inlet manifold though , I will indeed give you a pm very much appreciated 👍
Post #523633 2nd Aug 2019 7:31pm
Page 1 of 3 123>
