Home > Maintenance & Mods (L322) > aux belt squeal
Hoppo4.4tdv8
aux belt squeal
my 2011 4.4 has a squeal that's gotten worse for the last few months.
I've traced it to the idler above the alternator on the left hand side asy you look under the bonnet.
so I got the part how hard an it be.........
HARD is the answer. had a quick go last night and all I can day is what a pig. gave up.
as far as I can see there is no room at all so you need to remove the
rads
boost hoses and the alloy coolant hose just to get to the 1 bolt holding it on.
rant over
Post #515568 17th May 2019 6:41am
Baltic Blue
http://www.fullfatrr.com/forum/topic48934.html
From wiki. Thumbs Up G reg 2.5VM Vogue Portofino red 1991- 1999
Post #515572 17th May 2019 7:54am
Hoppo4.4tdv8
good info unfortunately it's not the tensioner that's at fault on mine. it's the idler pulley above the alternator next to the fan drive
Post #515573 17th May 2019 8:16am
Baltic Blue
Sorry, my mistake, should have read it more carefully.
Post #515574 17th May 2019 8:22am
DrRob
My squeak was the tensioner.... Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #515577 17th May 2019 9:35am
cass
Mine also turned out to be the tensioner but rather than risk doing the job twice I changed both belts, idler & tensioner while I had it in bits
Post #515615 17th May 2019 2:09pm
Hoppo4.4tdv8
the biggest thing is I cant see how you remove the metal coolant pipe without having to pull the rad
Post #515645 17th May 2019 6:53pm
rjff
I think you'll find the metal pipe will be the AC line and ISTR it can be moved to allow the fan and shroud removal.
Couple of links to start if I'm on the right job Smile
https://www.fullfatrr.com/forum/topic48934...=tensioner
https://www.fullfatrr.com/forum/topic48934.html
https://www.fullfatrr.com/forum/topic50269.html
Hope it helps. Cheers
Richard
Gap IIDBT
Post #515699 18th May 2019 9:45am
