![]() | Home > Maintenance & Mods (L322) > aux belt squeal |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3788 ![]() ![]() ![]() |
http://www.fullfatrr.com/forum/topic48934.html
Hoppo4.4tdv8 Member Since: 14 Dec 2018 Location: Leicestershire Posts: 16 ![]() ![]() |
good info unfortunately it's not the tensioner that's at fault on mine. it's the idler pulley above the alternator next to the fan drive |
Sorry, my mistake, should have read it more carefully.
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4320 ![]() ![]() ![]() |
My squeak was the tensioner.... Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
cass Member Since: 12 Oct 2011 Location: northumberland Posts: 751 ![]() ![]() |
Mine also turned out to be the tensioner but rather than risk doing the job twice I changed both belts, idler & tensioner while I had it in bits |
the biggest thing is I cant see how you remove the metal coolant pipe without having to pull the rad |
rjff Member Since: 28 Oct 2017 Location: Cambridgeshire Posts: 1196 ![]() ![]() ![]() |
I think you'll find the metal pipe will be the AC line and ISTR it can be moved to allow the fan and shroud removal.
