Home > In Car Electronics (L322) > iPad mini Sat Nav + Gap iid.
Baltic Blue
I am playing with using my iPad mini as a Sat Nav (either using Google maps or Waze) at present, but I have also been reading that I can set up a second app using “split screen”.
Is it possible to use the Gap iid App at the same time?, and thus display live data such as DPF soot level at the same time?
I have not had much success using both, but individually, they are fine.
I have temporarily rigged up a removable mount for my iPad and am hoping someone can offer help.
Cheers
Post #511024 5th Apr 2019 3:09pm
just googled this Mike,
Use two apps at the same time with Split View
Open an app.
Swipe up from the bottom of the screen to open the Dock.
On the Dock, touch and hold the second app that you want to open, then drag it off the dock.
When the app opens in Slide Over, drag down.
any good?
Post #511031 5th Apr 2019 3:49pm
Bushy30
United Kingdom 2011 Range Rover Vogue SE TDV8 Galway Green
Edit -- misunderstood the question -- going away quietly Current: 2011 FFRR Vogue SE 4.4 TDV8
Previous: -
2004 FFRR Vogue 4.4 V8 with LPG
1997 P38 4.0 SE with LPG
1997 P38 4.6 Vogue with LPG
Post #511032 5th Apr 2019 3:49pm
Is the multi app function on your iPad switched on?
Settings > General > Multitasking and dock > Allow multiple apps.
Post #511041 5th Apr 2019 4:34pm
Baltic Blue
Thanks Stan,
Will try again tomorrow.
Yes it’s an iPad mini 4.
Post #511055 5th Apr 2019 6:34pm
Baltic Blue
Nice day,it is now thanks to you 👍👍.
Post #511057 5th Apr 2019 6:40pm
Post #511058 5th Apr 2019 6:46pm
Baltic Blue
I am getting there Rolling with laughter Rolling with laughter Just not sure where I am going Thumbs Up
Post #511108 6th Apr 2019 9:46am
Boxbrownie
United Kingdom 2008 Range Rover Vogue SE TDV8 Java Black
Looking at the map.......I’d stay where you are Rolling with laughter David
Please let me know if my comments upset you, I may wish to upset you again.
Post #511119 6th Apr 2019 10:47am
Baltic Blue
The Google Maps as a sat nav works well, certainly better than the 2010 maps on my car, but being able to watch the soot level changing as it does a passive regen on a local test run looks promising.
Post #511139 6th Apr 2019 2:23pm
how come the map is overlaid on the gap info and not on a separate screen?
Post #511142 6th Apr 2019 3:32pm
Baltic Blue
Rome wasn’t built in a day.....
It’s a work in progress..
Tomorrow I am going to try and get the maps as the main screen, with a narrow margin screen showing “ live values”.
Mike.👍 G reg 2.5VM Vogue Portofino red 1991- 1999
Post #511143 6th Apr 2019 3:42pm
If you wish to go to "split screen" rather than in the "slide over" mode you have at the moment you just need to put your finger on the small grey bar at the top centre of the "slide over" and move your finger down the screen. The "slide over"
app will then convert to split screen. Thumbs Up
If you wish the map as the larger part of the screen open that app first and then draw up the info app as the side screen and then convert to split screen as above.
Also if you have split screen mode and wish to go back to slide over mode just touch the top grey bar again.
Also if you wish to have the two portions of the screen equal in size or any other configuration just put you finger on the line dividing the two apps and move your finger left or right as you wish and the dividing line will move with your finger.
Simples. Very Happy
Post #511146 6th Apr 2019 5:25pm
Baltic Blue
Nice day,
Thanks you for sharing your iPad expertise .
Mike.
PS
Lovely part of the world you live in.
I have visited Anthorne several times back in my working life.
Cheers. G reg 2.5VM Vogue Portofino red 1991- 1999
Post #511147 6th Apr 2019 5:37pm
Can see the Anthorn masts about a mile along the coast. Thumbs Up
At least our clocks are always correct. Cool
Post #511149 6th Apr 2019 5:42pm
