![]() | Home > In Car Electronics (L322) > iPad mini Sat Nav + Gap iid. |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3772 ![]() ![]() ![]() |
I am playing with using my iPad mini as a Sat Nav (either using Google maps or Waze) at present, but I have also been reading that I can set up a second app using “split screen”.
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35327 ![]() ![]() |
just googled this Mike,
Bushy30 Member Since: 03 Jun 2018 Location: Oxfordshire Posts: 1098 ![]() ![]() ![]() |
Edit -- misunderstood the question -- going away quietly Current: 2011 FFRR Vogue SE 4.4 TDV8
Thanks Stan,
Nice day,it is now thanks to you 👍👍.
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3977 ![]() ![]() ![]() |
I am getting there |
Boxbrownie Member Since: 19 May 2018 Location: FF gone now....FL2 i6 to play with Posts: 245 ![]() ![]() ![]() |
Looking at the map.......I’d stay where you are |
The Google Maps as a sat nav works well, certainly better than the 2010 maps on my car, but being able to watch the soot level changing as it does a passive regen on a local test run looks promising.
how come the map is overlaid on the gap info and not on a separate screen? |
Rome wasn’t built in a day.....
If you wish to go to "split screen" rather than in the "slide over" mode you have at the moment you just need to put your finger on the small grey bar at the top centre of the "slide over" and move your finger down the screen. The "slide over"
Nice day,
Can see the Anthorn masts about a mile along the coast. |
