![]() | Home > Maintenance & Mods (L322) > Rear Disc Brakes - Question |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6418 ![]() ![]() |
Link to "bedding in procedure"
I have been refurbing my rear brakes this week, think I have a sticky caliper on the RHS, pads worn down to the metal near enough, and a vibration when hitting 70. A few photos and tips:
MikeO Member Since: 02 Jan 2018 Location: The Cotswolds Posts: 526 ![]() ![]() ![]() |
Be interested to know how you get on with bedding-in. When I tried it never seemed to exit correctly. EPB seems okay but not as good as it could be. I should have another go at it but it's such a |
berkshirelad Member Since: 06 Apr 2016 Location: Newbury Posts: 265 ![]() ![]() ![]() |
Since my RR is an automatic, what's the point of the EPB.
Bit like jumping out of an aeroplane with only a single parachute, then |
scotcruz Member Since: 03 May 2017 Location: S C O T L A N D Posts: 391 ![]() ![]() ![]() |
Thanks all and Joe for the pictures. Guess I will take the negative battery cable off to be on the safe side.
Sorry, I forgot to add that I used the "pull fuse 36" method to disable the EPB. Given it took @ three days with real world issues and paint drying meant I could lock the car up at night (not that anyone would have had much fun trying to steal it with no wheels or brakes) |
The bedding in procedure went well .
Not sure if it does...tbh I lost count so not sure if I did less than or more than 10 |
Ah, maybe mine did complete successfully then. I was sure that on the Disco there was some sort of indication of success. 2016 Skoda Octavia VRS Estate
