Home > Maintenance & Mods (L322) > Rear Disc Brakes - Question
There is a re bedding/balancing procedure which is probably worth following as well (well there was on my 07 when I did that) as it makes sure they are adjusted correctly after reinstalling. There is nothing that can't be fixed with a hammer😜😜
Post #504743 10th Feb 2019 7:55pm
Link to "bedding in procedure"
for when new brake shoes or discs fitted .
Post #504988 13th Feb 2019 12:50am
I have been refurbing my rear brakes this week, think I have a sticky caliper on the RHS, pads worn down to the metal near enough, and a vibration when hitting 70. A few photos and tips:
Safety First
State of RHS pads
Outside not too bad
Inside a bit mucky
Kurusting
New Shoes
Suggest fit cable adjuster, then shoes and refit the pins to hold in place, along with the lower adjuster. then fit the springs, using suitable levers and/or string/wire
All back together
I used Hammerite smooth black and silver for all the parts, see how that copes with the heat...
Now off to carry out the bedding in procedure Wink .
Post #505212 15th Feb 2019 12:15pm
MikeO
Scotland 2009 Range Rover Vogue TDV8 Buckingham Blue
Be interested to know how you get on with bedding-in. When I tried it never seemed to exit correctly. EPB seems okay but not as good as it could be. I should have another go at it but it's such a Censored to find a suitable bit of road... 2016 Skoda Octavia VRS Estate
<gone>2009 FF Vogue TDV8 Buckingham Blue</gone>
<gone>2015 BMW 520D SE (not my favourite car)</gone>
<gone>2009 D3 HSE Galway Green</gone>
Post #505217 15th Feb 2019 1:09pm
berkshirelad
United Kingdom 2007 Range Rover Vogue SE TDV8 Tonga Green
Since my RR is an automatic, what's the point of the EPB.
Like previous automatics I have owned, the handbrake is only used for the MoT test!!
Post #505296 15th Feb 2019 8:49pm
Bit like jumping out of an aeroplane with only a single parachute, then Twisted Evil .
Post #505302 15th Feb 2019 9:48pm
scotcruz
Scotland 2010 Range Rover HSE TDV8 Zambezi Silver
Thanks all and Joe for the pictures. Guess I will take the negative battery cable off to be on the safe side.
Have ordered the parts so awaiting delivery. The weather is getting milder so thats a bonus. Will report back. Current:
- L560 Velar HSE R-Dynamic D180
- Peugeot 508 2011 - 2.2 HDi GT
Past:
- FFRR V 2010 - 3.6 TDV8
- Citroen C4 1.6i Petrol
- Mitsubishi Shogun 3.2 DID
- Peugeot 607 2.2 HDi
- Nissan Primera 1.8 SVE
- Honda Civic 1.6 VTEC
Post #505441 17th Feb 2019 9:11am
Sorry, I forgot to add that I used the "pull fuse 36" method to disable the EPB. Given it took @ three days with real world issues and paint drying meant I could lock the car up at night (not that anyone would have had much fun trying to steal it with no wheels or brakes) Thumbs Up .
Post #505455 17th Feb 2019 11:26am
The bedding in procedure went well .
Post #505464 17th Feb 2019 12:03pm
MikeO
Just out off interest, how does it indicate successful completion of the test? (It was a while ago I attempted it). 2016 Skoda Octavia VRS Estate
Post #505544 18th Feb 2019 10:11am
Not sure if it does...tbh I lost count so not sure if I did less than or more than 10 Embarassed
You just have to cycle the ignition when finished, otherwise it stays in test cycle.
What the procedure doesn't tell you is to hold the button in the "ON" position until the car comes to a stop.
Going down a hill, this can take some time Thumbs Up
And remembering that your stop lights are not coming on ?! (Although I couldn't see if they were....) .
Post #505546 18th Feb 2019 10:25am
MikeO
Ah, maybe mine did complete successfully then. I was sure that on the Disco there was some sort of indication of success. 2016 Skoda Octavia VRS Estate
Post #505566 18th Feb 2019 1:25pm
