Home > In Car Electronics (L405) > L405 Sat Nav repair |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16180 |
Basics first... Try a battery reset first 👍 |
6th Feb 2019 11:48pm |
Nigelhirst Member Since: 17 Aug 2018 Location: Shropshire Posts: 9 |
Yep. All it did was get Tracker excited...😀 2013 Vogue SDV8
7th Feb 2019 12:00am |
Re-flash your existing module?
7th Feb 2019 12:11am |
I didn’t specifically request the dealer tried that....maybe I should go back! 2013 Vogue SDV8
7th Feb 2019 12:31am |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 34949 |
if the nav is set on belgium then it wont allow UK postcodes....can you change the country to UK.. |
7th Feb 2019 4:18pm |
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3196 |
+1
7th Feb 2019 4:30pm |
Philip Member Since: 05 Jan 2010 Location: UK Posts: 2523 |
Yes, I discovered that after about twenty attempts at entering a postcode... |
7th Feb 2019 5:57pm |
Yes - every time I turn the engine on I have to resent the country to GBR, where it stays until I turn it off. (Apparently the sat nav manufacturer is based in Belgium).
7th Feb 2019 6:03pm |
Fifth Horseman Member Since: 04 Jul 2016 Location: Lanarkshire Posts: 208 |
This is a known failure mode with the Integrated Audio Module - it is referred to in LTB00642v3, it affects FFRR, RRS, D4, FL2 and Ewoks built between approximately 2012-2014.
7th Feb 2019 10:12pm |
DrF Member Since: 30 Jun 2014 Location: South East Posts: 1266 |
7th Feb 2019 11:05pm |
e600 Member Since: 28 Apr 2016 Location: Surrey Posts: 23 |
27th Nov 2022 9:55pm |
Kot Member Since: 10 Mar 2021 Location: broadland Posts: 1105 |
I had an issue where it indicated on the in control app I was 30 odd miles away but cant remember if it effected the sat nav!! I suspect maybe not.
28th Nov 2022 10:37am |
Thanks for the info, is resetting the codes something I can do or is it a garage job? |
28th Nov 2022 12:56pm |
I have a cheap autel AP200, blue tooth to iPhone simple to use, there are other makes available. It scans and resets among other things. read the blurb
28th Nov 2022 3:27pm |
