Home > In Car Electronics (L405) > L405 Sat Nav repair
Nigelhirst
United Kingdom 2013 Range Rover Vogue SDV8 Luxor
L405 Sat Nav repair
Hi All.
The satnav on my 2013 Vogue has just failed, in that on startup it thinks it is in the centre of Brussels, defaults to search country Belgium, won’t let me enter postcodes and loses all its settings when the ignition is off. After a while it finds where it is, so the GPS is functioning.
The dealer has quoted £1750 for a new ‘infotainment’ module.
I’m trying to pursue this through the extended warranty, but I’m not hopeful.
Any ideas who I could approach to repair it?
Many thanks 2013 Vogue SDV8
2014 Defender 90
2009 Freelander 2
Post #504215 6th Feb 2019 10:44pm
Basics first... Try a battery reset first 👍
Post #504217 6th Feb 2019 10:48pm
Nigelhirst
Yep. All it did was get Tracker excited...😀 2013 Vogue SDV8
2014 Defender 90
2009 Freelander 2
Post #504219 6th Feb 2019 11:00pm
Re-flash your existing module?
Got to be worth a try first!
Post #504222 6th Feb 2019 11:11pm
Nigelhirst
I didn’t specifically request the dealer tried that....maybe I should go back! 2013 Vogue SDV8
2014 Defender 90
2009 Freelander 2
Post #504223 6th Feb 2019 11:31pm
if the nav is set on belgium then it wont allow UK postcodes....can you change the country to UK..
Post #504313 7th Feb 2019 3:18pm
Weegie
+1
My understanding is that the default at start up after a reset is Belgium for some reason. It certainly is for the L322. John
GAP iiD BT
Post #504314 7th Feb 2019 3:30pm
Philip
2019 Range Rover Autobiography SDV8 Aintree Green
Yes, I discovered that after about twenty attempts at entering a postcode...
Post #504335 7th Feb 2019 4:57pm
Nigelhirst
Yes - every time I turn the engine on I have to resent the country to GBR, where it stays until I turn it off. (Apparently the sat nav manufacturer is based in Belgium).
The postcode icon is permanently greyed-out, irrespective of which country is set.
Anyway, the extended warranty company has agreed to pay for the fix, so we will never know....
Nigel 2013 Vogue SDV8
2014 Defender 90
2009 Freelander 2
Post #504339 7th Feb 2019 5:03pm
Fifth Horseman
Scotland 2018 Range Rover Vogue SE SDV8 Carpathian Grey
This is a known failure mode with the Integrated Audio Module - it is referred to in LTB00642v3, it affects FFRR, RRS, D4, FL2 and Ewoks built between approximately 2012-2014.
As this always happens on start-up then a replacement IAM is required, if it was intermittent then a software flash may cure it.
I had the same fault with the Nav on my D4 and a replacement unit from eBay cured it - and came with more up to date mapping Smile (cost about £120 iirc)
Post #504384 7th Feb 2019 9:12pm
DrF
United Kingdom 2013 Range Rover SVAutobiography 5.0 SC V8 Orkney Grey
Thumbs Up Thumbs Up
Post #504390 7th Feb 2019 10:05pm
e600
United Kingdom 2006 Range Rover Vogue 4.4 V8 Zermatt Silver
My 2013 AB satnav indicated Belgium, then after resetting it to GB worked fine for a week or so.
Now on startup it thinks it’s in Bracknell.
I have been through menu options but can’t get it to identify where it is. It indicated GPS is connected.
Any ideas anyone?
TIA
Post #649316 27th Nov 2022 8:55pm
Kot
I had an issue where it indicated on the in control app I was 30 odd miles away but cant remember if it effected the sat nav!! I suspect maybe not.
I did a DTC scan and their was a fault on the telemetric module after re setting the codes, the problem disappeared. 2018 SE SDV8 4.4 Byron Blue
Post #649337 28th Nov 2022 9:37am
e600
Thanks for the info, is resetting the codes something I can do or is it a garage job?
Post #649346 28th Nov 2022 11:56am
Kot
I have a cheap autel AP200, blue tooth to iPhone simple to use, there are other makes available. It scans and resets among other things. read the blurb
https://www.autelstore.co.uk/wholesale/aut...anner.html 2018 SE SDV8 4.4 Byron Blue
Post #649353 28th Nov 2022 2:27pm
