![]() | Home > In Car Electronics (L405) > L405 Sat Nav repair |
Basics first... Try a battery reset first 👍 |
Nigelhirst Member Since: 16 Aug 2018 Location: Shropshire Posts: 9 ![]() ![]() ![]() |
Yep. All it did was get Tracker excited...😀 2013 Vogue SDV8
Re-flash your existing module?
I didn’t specifically request the dealer tried that....maybe I should go back! 2013 Vogue SDV8
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35483 ![]() ![]() |
if the nav is set on belgium then it wont allow UK postcodes....can you change the country to UK.. |
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3244 ![]() ![]() ![]() |
+1
Philip Member Since: 05 Jan 2010 Location: UK Posts: 2591 ![]() ![]() |
Yes, I discovered that after about twenty attempts at entering a postcode... |
Yes - every time I turn the engine on I have to resent the country to GBR, where it stays until I turn it off. (Apparently the sat nav manufacturer is based in Belgium).
Fifth Horseman Member Since: 04 Jul 2016 Location: Lanarkshire Posts: 230 ![]() ![]() ![]() |
This is a known failure mode with the Integrated Audio Module - it is referred to in LTB00642v3, it affects FFRR, RRS, D4, FL2 and Ewoks built between approximately 2012-2014.
DrF Member Since: 30 Jun 2014 Location: South East Posts: 1435 ![]() ![]() ![]() |
e600 Member Since: 28 Apr 2016 Location: Surrey Posts: 23 ![]() ![]() ![]() |
Kot Member Since: 10 Mar 2021 Location: broadland Posts: 1260 ![]() ![]() |
I had an issue where it indicated on the in control app I was 30 odd miles away but cant remember if it effected the sat nav!! I suspect maybe not.
Thanks for the info, is resetting the codes something I can do or is it a garage job? |
I have a cheap autel AP200, blue tooth to iPhone simple to use, there are other makes available. It scans and resets among other things. read the blurb
