![]() | Home > Technical (L322) > Steering angle sensor gremlins - Electrical help required! |
ohuntsman Member Since: 21 Mar 2016 Location: Surrey Posts: 337 ![]() ![]() ![]() |
Hi there, so I have just replaced this and it hasn’t fixed the non communication. Any suggestions?? |
OK so update - the code reader only reads the angle as I turn left - then there are weird numbers to the right - I'm guessing a faulty wire, any suggesions? |
UPDATE.
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35611 ![]() ![]() |
before this gets to complicated, have you done a battery reset and set the steering parameters? |
Thanks Stan
Update. So before cutting into my loom I decided to double check continuity and it was there.
kds2 Member Since: 30 Sep 2017 Location: lincoln Posts: 225 ![]() ![]() ![]() |
icarsoft read and clear faults only, have to take it somewhere that can program it. |
Thanks both - did you have to code the SAS before it would reset the SAS? |
Have replaced the steering angle sensor and am getting the same weird readings. which would lead me to believe that the issue is in the CAN BUS - any tips for fixing this?? |
As per my earlier post I realise I cannot simply splice in and run a singlar wire to replace it |
ramigojag Member Since: 29 Oct 2018 Location: Sydney Posts: 17 ![]() ![]() ![]() |
Yes the steering angle sensor information is transmitted along the CAN bus for all modules to see and use.
OK so happy days! HAve found the issue
