Home > Technical (L322) > Steering angle sensor gremlins - Electrical help required!
ohuntsman
United Kingdom 2002 Range Rover Vogue 4.4 V8 Zambezi Silver
Hi there, so I have just replaced this and it hasn’t fixed the non communication. Any suggestions??
Post #496286 22nd Nov 2018 12:42pm
ohuntsman
OK so update - the code reader only reads the angle as I turn left - then there are weird numbers to the right - I'm guessing a faulty wire, any suggesions?
Post #496287 22nd Nov 2018 1:37pm
ohuntsman
UPDATE.
Circuit diagram for reference.
I have checked the loom's continuity from Steering angle sensor terminal C0962-4 to ABS ECU terminal C0506-40 and there is continuity.
Although from SAS terminal C0862-3 to ABS ECU terminal C0506-24 there is no continuity.
I wanted to check if there was continuity to C0506-24, there is a splice X18836 into the Engine Control Module, I checked the loom's continuity from the ABS ECU C0506-24 to the ECM C0331-36 and there is continuity.
QUESTION - does the CANBUS communicate the steering angle????
There fore if I replace this wire will the SAS reset???
Post #496289 22nd Nov 2018 2:38pm
before this gets to complicated, have you done a battery reset and set the steering parameters?
Post #496294 22nd Nov 2018 3:28pm
ohuntsman
Thanks Stan
Do you mean battery off and full lock each way?
If so yes- it won't reset.
As per earlier in the thread I get a good output on my diagnostic reading with the steering wheel to the left, as soon as the column goes past centre to the right I get an odd output - I think there is a break in the wire - see piccies please
Post #496295 22nd Nov 2018 3:40pm
ohuntsman
Update. So before cutting into my loom I decided to double check continuity and it was there.
Have ordered a second hand SAS to see if I get a better signal. Will test it before swapping it over on the steering column.
Post #496531 25th Nov 2018 1:14am
lounge_on_wheels
Australia 2003 Range Rover HSE Td6 Zambezi Silver
When i replaced mine on a 203 i had to use iidtool Bt to advise the system that a new SAS was fitted, not sure if your carsoft reader has that function.
Post #496641 25th Nov 2018 9:18pm
kds2
England 2008 Range Rover Vogue TDV8 Stornoway Grey
icarsoft read and clear faults only, have to take it somewhere that can program it.
Post #496653 26th Nov 2018 12:03am
ohuntsman
Thanks both - did you have to code the SAS before it would reset the SAS?
Post #496739 26th Nov 2018 11:03pm
ohuntsman
Have replaced the steering angle sensor and am getting the same weird readings. which would lead me to believe that the issue is in the CAN BUS - any tips for fixing this??
Post #496818 27th Nov 2018 7:33pm
ohuntsman
As per my earlier post I realise I cannot simply splice in and run a singlar wire to replace it
Post #496820 27th Nov 2018 7:42pm
ramigojag
Australia 2003 Range Rover HSE 4.4 V8 Ipanema Sand
Yes the steering angle sensor information is transmitted along the CAN bus for all modules to see and use.
Have you performed the electronic calibration of the steering angle sensor?
I don't think the iCarsoft tool does it, but that's where I'd look next.
It does seem odd that the the sensor measures correctly turning left, but not turning right. I don't think this is a CAN fault as I think if there was a bad communication on the network you would get faults appear in various other systems relating to bad can signal or words to that effect.
Also was the original sensor you fitted new or second hand? The strange characters displayed strikes me more as a bug in the iCarsoft than info that would be transmitted by the car. Current:
2003 Range Rover V8 HSE
2014 BMW 125i
Previous:
2005 VW Golf GTI
2001 BMW E39 M5
1991 Peugeot 205 GTI 1.6
1995 Range Rover P38 4.6 HSE
1991 Suzuki SJ413
Too many others to mention
Post #496832 27th Nov 2018 8:59pm
ohuntsman
OK so happy days! HAve found the issue
All gremlins reset - the YAW DSC sensor was covered in sticky coca cola!! Waheey!!
Anyone got any good tips for removing the centre console and the Rear HVAC vent?
Post #497172 30th Nov 2018 8:15pm
