Home > Maintenance & Mods (L322) > air suspension inactive?
Northern lad
hi all
okay so here we go first problem just appeared in the message centre as the topic states, Air suspension inactive, I just drove it 50 miles, and it seems fine? no accompanying red warnings on the dash, should I be overly concerned, or do I only need worry if i'm off road?
any advice greatly appreciated
regards
Steve 2003 Vogue 4.4 petrol, silver 126k on clock when I got her
Post #484623 29th Jul 2018 2:29pm
You may not have noticed that all your EAS lights on the dash have gone out ?
Might fix itself with a steering wheel lock to lock or battery disconnection procedure (both). Otherwise a hard fault, that will need fault code reading and resetting. .
Post #484633 29th Jul 2018 4:47pm
Northern lad
thanks Joe
EAS? 2003 Vogue 4.4 petrol, silver 126k on clock when I got her
Post #484634 29th Jul 2018 4:53pm
mjdronfield
Electronic Air Suspension.....
The orange light near the suspension height selection knob..... 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #484646 29th Jul 2018 6:36pm
Northern lad
thanks for clarifying, the knob by the handbrake? (when I say knob by the handbrake, no I don't mean the driver Whistle ) if so, no lights at all on that?
just need a bit of patients guys complete newbie to all things RR 2003 Vogue 4.4 petrol, silver 126k on clock when I got her
Post #484650 29th Jul 2018 6:59pm
mjdronfield
On the dash....tells you what height suspension is at (though it’s not lit on this pic)
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #484651 29th Jul 2018 7:12pm
mjdronfield
The light is lit on this pic....
Video here shows the lights changing when you move the selection knob. He obv fixed the issue which he didn’t show.....
You need to get it diagnosed really, as Joe90 says, irs a fault that needs to be reset with a diagnostic tool, even if you fix the faulty part.
You need it working really as the car wontvself level and it lowers at higher speed to aid handling.... 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #484653 29th Jul 2018 7:23pm
bruno22rf
England 2004 Range Rover Vogue 4.4 V8 Java Black
If it turns out to be your pump then I have one here that you are welcome to - took it off my 04 4.4 as I thought there was a problem with it but the fault was not with the pump - I have put a new seal on it just to make sure - Im near Milton Keynes so if you want to pop in and fit it then you are welcome to it - takes about 20 minutes to fit.
Post #484673 29th Jul 2018 11:42pm
Northern lad
thanks chaps for your replies, and apologies for my delayed response
I haven't tried your suggestion yet Joe, will do when I get a chance
I might give the guy in the video a call, when I can,
Bruno thanks for the offer of your spare pump, I may need to take you up on that!
I don suppose it could be something simple as a fuse could it?
cheers all
Post #484784 31st Jul 2018 4:10am
If the lights are out you have a hard fault. It is a Range Rover, nothing as simple as a fuse Laughing - although it does happen...
What you need is one of these Wink
http://www.fullfatrr.com/forum/topic47878.html
The chap in the video will probably charge you that much to fix it or just diagnose the problem!! Shocked .
Post #484822 31st Jul 2018 4:50pm
mjdronfield
+1
I was only using the video to show the lights operating.
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #484824 31st Jul 2018 5:09pm
bruno22rf
Here if you need it, Steve, 99% sure its good but not sure how old it is although it doesn't look ancient.
Post #484849 31st Jul 2018 10:57pm
Northern lad
thanks chaps
I understand about the Vid thanks, i might consider the AA as a second port of call, after i try Joe's suggestion of full wheel lock, i dont know about disconnecting the battery, i read somewhere may have been in the Wiki section, there is a part that is designed to explode in the event of an impact Shocked Shocked so a bit worried about doing that TBH
Cheers Bruno, if it comes to it, please let me know how much you want PM if you want
Joe, I bought this a couple of years ago for my Jag, never been used, i downloaded 'Torque' pro software, would it work on the RR?
https://www.amazon.co.uk/dp/B00H9S71LW/ref...31_TE_dp_1
Regards
Post #484856 1st Aug 2018 6:38am
bruno22rf
Don't want anything for it Steve. Maybe a couple of quid next time you pass a charity box.
Post #484864 1st Aug 2018 7:25am
Northern lad
that's very decent of you Bruno, much appreciated, I happen to work for a charity, so consider that a done deal
regards
steve 2003 Vogue 4.4 petrol, silver 126k on clock when I got her
Post #484867 1st Aug 2018 7:36am
