![]() | Home > Maintenance & Mods (L322) > air suspension inactive? |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6419 ![]() ![]() |
You may not have noticed that all your EAS lights on the dash have gone out ?
Northern lad Member Since: 30 Jun 2018 Location: South London Posts: 56 ![]() ![]() |
thanks Joe
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7905 ![]() ![]() ![]() |
Electronic Air Suspension.....
thanks for clarifying, the knob by the handbrake? (when I say knob by the handbrake, no I don't mean the driver |
On the dash....tells you what height suspension is at (though it’s not lit on this pic)
Previous cars : 2003 Range Rover Vogue TD6 1999 Discovery Td5 ES 1995 BMW M5 3.8 6 speed 1992 Range Rover 3.9 Efi Vogue 1992 BMW M5 3.8 1988 BMW 735i SE 1989 Ford Sierra XR4x4 2.9i 1981 Ford Fiesta Supersport |
The light is lit on this pic....
Video here shows the lights changing when you move the selection knob. He obv fixed the issue which he didn’t show..... You need to get it diagnosed really, as Joe90 says, irs a fault that needs to be reset with a diagnostic tool, even if you fix the faulty part. You need it working really as the car wontvself level and it lowers at higher speed to aid handling.... 2011 Range Rover Vogue SE 4.4 TDV8 Previous cars : 2003 Range Rover Vogue TD6 1999 Discovery Td5 ES 1995 BMW M5 3.8 6 speed 1992 Range Rover 3.9 Efi Vogue 1992 BMW M5 3.8 1988 BMW 735i SE 1989 Ford Sierra XR4x4 2.9i 1981 Ford Fiesta Supersport |
bruno22rf Member Since: 08 Mar 2018 Location: milton keynes Posts: 69 ![]() ![]() ![]() |
If it turns out to be your pump then I have one here that you are welcome to - took it off my 04 4.4 as I thought there was a problem with it but the fault was not with the pump - I have put a new seal on it just to make sure - Im near Milton Keynes so if you want to pop in and fit it then you are welcome to it - takes about 20 minutes to fit. |
thanks chaps for your replies, and apologies for my delayed response
If the lights are out you have a hard fault. It is a Range Rover, nothing as simple as a fuse |
+1
Here if you need it, Steve, 99% sure its good but not sure how old it is although it doesn't look ancient. |
thanks chaps
Don't want anything for it Steve. Maybe a couple of quid next time you pass a charity box. |
that's very decent of you Bruno, much appreciated, I happen to work for a charity, so consider that a done deal
