![]() | Home > Maintenance & Mods (L322) > air suspension inactive? |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6418 ![]() ![]() |
You may not have noticed that all your EAS lights on the dash have gone out ?
Northern lad Member Since: 30 Jun 2018 Location: South London Posts: 56 ![]() ![]() |
thanks Joe
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7894 ![]() ![]() ![]() |
Electronic Air Suspension.....
thanks for clarifying, the knob by the handbrake? (when I say knob by the handbrake, no I don't mean the driver |
On the dash....tells you what height suspension is at (though it’s not lit on this pic)
The light is lit on this pic....
bruno22rf Member Since: 08 Mar 2018 Location: milton keynes Posts: 69 ![]() ![]() ![]() |
If it turns out to be your pump then I have one here that you are welcome to - took it off my 04 4.4 as I thought there was a problem with it but the fault was not with the pump - I have put a new seal on it just to make sure - Im near Milton Keynes so if you want to pop in and fit it then you are welcome to it - takes about 20 minutes to fit. |
thanks chaps for your replies, and apologies for my delayed response
If the lights are out you have a hard fault. It is a Range Rover, nothing as simple as a fuse |
+1
Here if you need it, Steve, 99% sure its good but not sure how old it is although it doesn't look ancient. |
thanks chaps
Don't want anything for it Steve. Maybe a couple of quid next time you pass a charity box. |
that's very decent of you Bruno, much appreciated, I happen to work for a charity, so consider that a done deal
