Home > Technical (L322) > queue assist 2011 4.4 tdv8 |
mark35gun Member Since: 01 Oct 2018 Location: swanwick Posts: 63 |
hi all, i have a 2011 ff 4.4 tdv8 and a shiny new IId tool to play with, i am trying to activate queue assist, mine has acc, and i have read that QA is software based, however when i activate it in the ccf the car comes up with various faults, airbag, forward assist, etc, i have scoured the forum and can't really find an answer, also i can't seem to see some parameters that others seem to be able to.
4th Oct 2018 11:53pm |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16298 |
You can't sir... The 322 never had this feature I'm afraid... Only available on the 405... |
5th Oct 2018 12:10am |
ok, thank you for that, that would explain it, one thing i don't understand is why it gives the option to turn it on in the ccf..... 2011 4.4 tdv8 autobiography black
5th Oct 2018 12:21am |
thank you for the info, that explains a lot, i will re-configure and clear the faults (again!)
5th Oct 2018 12:48am |
Bushy30 Member Since: 03 Jun 2018 Location: Oxfordshire Posts: 1098 |
You can Sir!!!!
5th Oct 2018 6:47am |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7818 |
There was a guy that retrofitted ACC to his car. Is that the same as Queue Assist?
5th Oct 2018 8:03am |
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2504 |
I retrofitted ACC and enabled queue assist at the same time. See the thread referenced above, page 2 in particular. |
5th Oct 2018 8:14am |
dolph34 Member Since: 14 Sep 2015 Location: Kildare Posts: 1724 |
I have it enabled on my 2011 VSE , it does work but its very 'grabby ' on the release from stanstill on mine. 2015 4.4 AB
5th Oct 2018 10:12am |
hi yes i read the thread on the ACC retrofit, that is what spurred me on to try, you mention beta software from gap, is that something that you can request from them? or do i already have it but needs to be activated?
5th Oct 2018 10:27am |
You need to ask GAP to enable full access on your tool which will then allow you to change all the necessary settings. |
5th Oct 2018 10:54am |
thanks, sent a request......... 2011 4.4 tdv8 autobiography black
5th Oct 2018 11:15am |
all configured and appears to work........
5th Oct 2018 2:44pm |
5th Oct 2018 8:22pm |
Andyv8 Member Since: 02 Feb 2019 Location: Lakes Posts: 15 |
I tried to activate queue assist today. When I activated the acc queue and acc queue stop and go I lose all crusie control. Do you need to do anything else other then activate it in the ccf files? I have full access on IID and the car had adaptive crusie from the factory. |
3rd Feb 2019 6:40pm |
