Home > Technical (L322) > queue assist 2011 4.4 tdv8
GraemeS
Are the 3 collision mitigation by braking parameters set?
I experienced mine working whilst using CC at 100 kph on a rural road when a vehicle ahead had mostly pulled off the left of the road just after the start of a bend to the right. I had started to steer to the right to give more clearance when forward alert sounded as it often does in traffic which I ignore then my vehicle braked very aggressively. If I hadn't stomped on the accelerator I think that my car would have stopped or almost stopped in time. This wasn't good for the vehicle behind that had been travelling too close for my liking, which afterwards kept its distance.
Post #503856 3rd Feb 2019 8:15pm
Andyv8
United Kingdom 2010 Range Rover Autobiography 5.0 SC V8 Java Black
I set 2 of them to gen 1 like your pics but I didn’t see the 3rd. It has forward alert standard and the acc brakes the car fine down to 20mph or what ever it is till crusie turns off. When I activate the queue assist I get no faults displaying or anything but when I try to set crusie nothing happens. It’s the 5.0 s/c that didn’t make a difference does it?
Post #503857 3rd Feb 2019 8:23pm
GraemeS
Collision mitigation by braking - fitted, further up the list.
The 5.0 uses a separate CC ecu whereas the 4.4's CC is provided by the ecm so the 5.0's ACC s/w might not have been as developed as the 4.4's. Is your ACC ecu's s/w at the latest L322 level? My 4.4's ECM s/w is still as built in April 12, not at the latest level.
Post #503863 3rd Feb 2019 9:11pm
Andyv8
IID tool did say there was a update for the acc ecu but when I clicked on it it didn’t do anything. I’ll have another look in the settings next weekend. Cheers for the help
Post #503865 3rd Feb 2019 9:21pm
GraemeS
You would have to purchase an update from Gap as they're not free.
Post #503871 4th Feb 2019 3:45am
mark35gun
United Kingdom 2011 Range Rover Autobiography Black TDV8 Santorini Black
hi andy, not as far as i remember, but i think mine did that as well, i just cleared those faults and that was it (from memory) 2011 4.4 tdv8 autobiography black
2006 td6 vogue buckingham blue
2000 p38 Holland&Holland gone, best car i ever had
1998 p38 vogue oslo blue gone
1998 50th edition v8 defender gone
1997 200 tdi defender red gone
1995 4.6 defender 90 green gone
Post #503878 4th Feb 2019 10:04am
