Home > Technical (L322) > The old "no sound" help |
Bushy30 Member Since: 03 Jun 2018 Location: Oxfordshire Posts: 1098 |
Phil,
4th Feb 2019 11:49am |
philip1972 Member Since: 16 Jun 2017 Location: Marval 87440 Posts: 523 |
Thanks-I have been inside the BM54, that looked good.
4th Feb 2019 11:51am |
Hi Phil,
4th Feb 2019 12:06pm |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3972 |
As above you really need to look inside the various module cases for corrosion.
4th Feb 2019 12:12pm |
Thanks all.
4th Feb 2019 12:14pm |
gj88 Member Since: 10 Sep 2018 Location: West Midlands Posts: 213 |
With sound off and screen on, I'd start with the DSP and then work your way out. Good chance it'll be that one |
4th Feb 2019 12:28pm |
SilverParrot Member Since: 09 Aug 2018 Location: Herts Posts: 25 |
Same fault on mine was caused by a dodgy pin on the DSP |
4th Feb 2019 12:49pm |
I am getting confused here with whats what!!! Boxes in there are the DSP, Amp, TV, nav radio module etc etc )
4th Feb 2019 1:23pm |
It's the vertical black box with 3 plugs on the top nearest the back of the car. |
4th Feb 2019 1:26pm |
Found a wet and dirty connector on the top of the TV module. Not sure if that can affect things but will clean anyway |
4th Feb 2019 1:30pm |
Don't assume that it'll be the only one -- the inside of my DSP was GREEN and crusty! Current: 2011 FFRR Vogue SE 4.4 TDV8
4th Feb 2019 1:35pm |
Whats the best way to clean the pins and socket?
4th Feb 2019 1:45pm |
Use a good contact cleaner with a soft toothbrush - -and don't brush too hard Current: 2011 FFRR Vogue SE 4.4 TDV8
4th Feb 2019 1:58pm |
The three plugs can definitely be undone. You definitely need to get the biggest plug undone and check for corrosion. There is a slide clip on the plug you need to undo before the plug will come out.
