Home > Technical (L322) > queue assist 2011 4.4 tdv8
mark35gun
United Kingdom 2011 Range Rover Autobiography Black TDV8 Santorini Black
hi all, i have a 2011 ff 4.4 tdv8 and a shiny new IId tool to play with, i am trying to activate queue assist, mine has acc, and i have read that QA is software based, however when i activate it in the ccf the car comes up with various faults, airbag, forward assist, etc, i have scoured the forum and can't really find an answer, also i can't seem to see some parameters that others seem to be able to.
can anyone help or point me in the right direction please 2011 4.4 tdv8 autobiography black
2006 td6 vogue buckingham blue
2000 p38 Holland&Holland gone, best car i ever had
1998 p38 vogue oslo blue gone
1998 50th edition v8 defender gone
1997 200 tdi defender red gone
1995 4.6 defender 90 green gone
Post #491009 4th Oct 2018 11:53pm
You can't sir... The 322 never had this feature I'm afraid... Only available on the 405... Thumbs Up
Post #491011 5th Oct 2018 12:10am
mark35gun
ok, thank you for that, that would explain it, one thing i don't understand is why it gives the option to turn it on in the ccf..... 2011 4.4 tdv8 autobiography black
Post #491012 5th Oct 2018 12:21am
there is plenty on there that is descriptive for other models... Jags etc etc... They all seem to cross over when it comes to CCF’s
Post #491013 5th Oct 2018 12:34am
mark35gun
thank you for the info, that explains a lot, i will re-configure and clear the faults (again!)
much obliged 2011 4.4 tdv8 autobiography black
Post #491014 5th Oct 2018 12:48am
Bushy30
United Kingdom 2011 Range Rover Vogue SE TDV8 Galway Green
You can Sir!!!!
Not that I have yet, but...... Do a search for it, there is a member who has done it description is in the thread Smile Current: 2011 FFRR Vogue SE 4.4 TDV8
Previous: -
2004 FFRR Vogue 4.4 V8 with LPG
1997 P38 4.0 SE with LPG
1997 P38 4.6 Vogue with LPG
Post #491031 5th Oct 2018 6:47am
mjdronfield
There was a guy that retrofitted ACC to his car. Is that the same as Queue Assist?
Thought it was different.
You might mean another thread altogether of course....
http://www.fullfatrr.com/forum/topic42331.html?highlight=acc 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #491042 5th Oct 2018 8:03am
GraemeS
I retrofitted ACC and enabled queue assist at the same time. See the thread referenced above, page 2 in particular.
Post #491045 5th Oct 2018 8:14am
dolph34
Ireland 2015 Range Rover Autobiography SDV8 Corris Grey
I have it enabled on my 2011 VSE , it does work but its very 'grabby ' on the release from stanstill on mine. 2015 4.4 AB
GSXR 1000 K5
R1 1998
Post #491061 5th Oct 2018 10:12am
mark35gun
hi yes i read the thread on the ACC retrofit, that is what spurred me on to try, you mention beta software from gap, is that something that you can request from them? or do i already have it but needs to be activated?
i cannot see most of the values that you have set in the ccf, i was thinking that this may be the cause of all the faults, as in some more parameters need to be set in order for QA to function correctly, i love the car and think its one of JLRs best incarnations, i also like gadgets especially when they work well!
If i turn off QA in the ccf then all faults disappear, although i have activated it at the mo and cleared the faults and they appear to remain cleared, but as yet i have not road tested it with QA enabled, so i am a little stuck, i am fairly sure the QA is not configured properly, but cannot see the parameters that GraemeS can.
BTW forward assist and ACC work normally in my car and show no faults until QA is enabled
any help would be much appreciated 2011 4.4 tdv8 autobiography black
Post #491063 5th Oct 2018 10:27am
GraemeS
You need to ask GAP to enable full access on your tool which will then allow you to change all the necessary settings.
Post #491066 5th Oct 2018 10:54am
mark35gun
thanks, sent a request......... 2011 4.4 tdv8 autobiography black
Post #491068 5th Oct 2018 11:15am
mark35gun
all configured and appears to work........
thanks to all 2011 4.4 tdv8 autobiography black
Post #491093 5th Oct 2018 2:44pm
GraemeS
Post #491141 5th Oct 2018 8:22pm
Andyv8
United Kingdom 2010 Range Rover Autobiography 5.0 SC V8 Java Black
I tried to activate queue assist today. When I activated the acc queue and acc queue stop and go I lose all crusie control. Do you need to do anything else other then activate it in the ccf files? I have full access on IID and the car had adaptive crusie from the factory.
Post #503849 3rd Feb 2019 6:40pm
