![]() | Home > Technical (L322) > Egr delete... |
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3254 ![]() ![]() ![]() |
RichM63 Member Since: 10 Jul 2019 Location: Brittany Posts: 249 ![]() ![]() ![]() |
Correct. Leave all wiring connected. Best.. |
Thanks to both. |
Red Merle Member Since: 19 Sep 2016 Location: Cornwall Posts: 2158 ![]() ![]() ![]() |
A little background reading on NOx:
rar110 Member Since: 09 Aug 2014 Location: Brisbane, Australia Posts: 1119 ![]() ![]() ![]() |
If you unplug the EGR, the ECU will identify it and you will get a fault. So either leave it plugged in or plug in emulators instead of the EGRs. ______________________________
Brian S Member Since: 07 Jul 2019 Location: Essex Posts: 9 ![]() ![]() ![]() |
My 2007 model has been playing up a bit and I don't know if the EGR is at fault.
ur20v Member Since: 19 Feb 2019 Location: None Posts: 634 ![]() ![]() |
Deleted |
Well i've just ordered a set off ebay so ill report back my results. |
Deleted . |
Grofus Member Since: 24 Mar 2017 Location: Co Clare Posts: 577 ![]() ![]() ![]() |
Having read the article it appears to be all true to a point. However, there is no mention of Dpf's capturing the danderous particles and the fact that Nox gasses are unstable and dissipate within 20 mins. The Egr system is fundamentally flawed in that it destroys engines slowly by choking them up causing rough running that increase emissions and eventually self distruction. There are much better ways to control Nox emissions. It is simply a case of reducing the temerature of combustion. Water injection was used in 2nd world war, Ffs. I have personally tested equipment easily retro fitted to any car or truck that has reduced all emissions to virtually zero. That was after removing the DPF and egr. MOT tester's were, in their own words, astounded but couldn't give me an MOT as it didnt meet regulations. Farcical is the only term for the gov's handling of the issue. The policies are about increasing revenue. Its that simple. 2007 Vogue TDV8 in Zermatt Silver with Charcoal |
Deleted |
Yeah, i hadn't considered the lack of CO2 for plants and trees, but you are right. Really |
Brian Considine Member Since: 15 Apr 2019 Location: Garlinge Posts: 428 ![]() ![]() |
In general, I agree with most of what Grofus & ur20v say.
Andy Member Since: 24 Feb 2009 Location: Shropshire Posts: 2944 ![]() ![]() ![]() |
I was messaging the owner of Alive Tuning two weeks ago and he said I should refit the EGRs? Mine is already remapped including digital EGR deleted but I didn’t know about this until longer after I’d bought the car, by which time I’d mechanically deleted the EGRs.
