![]() | Home > Technical (L322) > MY 10 electric problem |
CS Member Since: 14 Apr 2015 Location: Edinburgh Posts: 1401 ![]() ![]() ![]() |
You might need to do a system re-set, ideally with a diagnostic machine. There is the possibility that taking the leads off the battery and shorting the leads together (away from the battery) might work (referred to as a "hard reset" on here I think) but while that was done to my 2004 car when its battery failed in a remote location, I'm not expert enough to say whether that would work (and be safe) for yours, perhaps someone else who knows more can help. Only Range Rovers since 1988 |
Donnie Member Since: 14 Aug 2018 Location: Thueringen Posts: 15 ![]() ![]() ![]() |
i tried that the OBD port is also not operational. i tried to connect the laptop. id like to check the fuses in the glove box, but i cant open it |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35641 ![]() ![]() |
check the battery connections .. ... - .- -.
i did and cleaned them too. it seems that the car does not wake up. is there a part which is related to that? |
with a fully charged battery you shouldn't have any starting problems..
its a complete new battery and i have coding charger plugged aswell. the windows are working on the left side not automatic, you have to hold the switch. the blower from the heating system runs at all stages. the cluster tries to start up and it gets light grey until shuts off again. |
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2647 ![]() ![]() |
What happened in the lead-up to fitting the new battery? |
a faulty old battery. i change it and drove the car to his parking spot disconnected the battery until i got back my painted part and know the does not do anything |
John w Member Since: 14 Jan 2018 Location: Cranleigh, Surrey Posts: 439 ![]() ![]() ![]() |
It does sound like your not getting any switched power.
so you have checked the battery and its fully charged? sometimes new ones are faulty or not charged up..
the battery has 13,7 Volt and the charger is on it.
What did you have painted? Is it something to which a lead is attached? |
the car runs again. if have no clue what it was. i unplug 100 times the battery and sudenly the cluster was operational |
same as yesterday i went down to the car, battery was connected and charged over night. |
