Home > Technical (L322) > MY 10 electric problem
Donnie
Germany 2011 Range Rover HSE 5.0 V8 Alaska White
Hi,
i havet trouble with my MY 10 5,0L V8 the car got a new battery and sice then it wont start.
the cluster is dark and it seems it trys to start but goes dark again. the windows and the ac unit works. The interior lights and unlook doors wont work.
has anyone an idea?
Regards
Post #486714 21st Aug 2018 10:14am
CS
You might need to do a system re-set, ideally with a diagnostic machine. There is the possibility that taking the leads off the battery and shorting the leads together (away from the battery) might work (referred to as a "hard reset" on here I think) but while that was done to my 2004 car when its battery failed in a remote location, I'm not expert enough to say whether that would work (and be safe) for yours, perhaps someone else who knows more can help. Only Range Rovers since 1988
Post #486718 21st Aug 2018 11:03am
Donnie
i tried that the OBD port is also not operational. i tried to connect the laptop. id like to check the fuses in the glove box, but i cant open it
Post #486720 21st Aug 2018 11:11am
check the battery connections .. ... - .- -.
Post #486725 21st Aug 2018 11:48am
Donnie
i did and cleaned them too. it seems that the car does not wake up. is there a part which is related to that?
Post #486729 21st Aug 2018 12:17pm
with a fully charged battery you shouldn't have any starting problems..
i would check the battery voltage next.. ... - .- -.
Post #486730 21st Aug 2018 12:25pm
Donnie
its a complete new battery and i have coding charger plugged aswell. the windows are working on the left side not automatic, you have to hold the switch. the blower from the heating system runs at all stages. the cluster tries to start up and it gets light grey until shuts off again.
Post #486733 21st Aug 2018 12:36pm
GraemeS
Australia
What happened in the lead-up to fitting the new battery?
Post #486737 21st Aug 2018 1:11pm
Donnie
a faulty old battery. i change it and drove the car to his parking spot disconnected the battery until i got back my painted part and know the does not do anything
Post #486739 21st Aug 2018 1:17pm
John w
United Kingdom 2011 Range Rover Autobiography Black TDV8 Barolo Black
It does sound like your not getting any switched power.
Have you tried locking the car with the key in the lock and unlocking it again ?
Somewhere in the manual it says where to place the key under the dash when it's battery is flat. That uses passive activation and may help.
I think the obd will only work in the accessory position, else the modules aren't woken up. Too many toys, not enough time
2011 4.4 TDV8 AB Black
Post #486751 21st Aug 2018 2:16pm
so you have checked the battery and its fully charged? sometimes new ones are faulty or not charged up..
if the above is ok then disconnect the battery , wait 30-40 minutes , re-connect and start the engine..as soon as the engine is running turn the steering wheel fully left and then fully right to set the steering parameters...
hopefully all will be well.. ... - .- -.
Post #486753 21st Aug 2018 2:18pm
Donnie
the battery has 13,7 Volt and the charger is on it.
i cant turn on the ignition if i push the button nothing happens.
Post #486756 21st Aug 2018 2:23pm
GraemeS
Australia
What did you have painted? Is it something to which a lead is attached?
Post #486792 21st Aug 2018 9:54pm
Donnie
the car runs again. if have no clue what it was. i unplug 100 times the battery and sudenly the cluster was operational
Post #486800 22nd Aug 2018 7:07am
Donnie
same as yesterday i went down to the car, battery was connected and charged over night.
Post #486809 22nd Aug 2018 7:52am
