Home > Technical (L322) > Auto Wipers
Page 3 of 6 <123456>
comports
United Kingdom 2016 Range Rover Autobiography SDV8 Mariana Black
Not yet mate - Any tips, screws etc I need to look out for to remove the whole console or is it just pull down affair..? Ash
2016 SDV8 AB
Post #64358 17th May 2011 6:47pm
comports
Follow up..
I was brave (no i didn't just pull it down). Found the two screws at the back and popped the console off. There was a very short flat connector up the front with 4 wires. Not the mic one as that is further back (near the cover) so I assume I have the wiring at least in place for the sensors..
Thumbs Up Ash
2016 SDV8 AB
Post #64377 17th May 2011 8:08pm
daveo
nice one Thumbs Up what happened with your LCM, V8 facelift Range Rover Autobiography 22" wheels.
Post #64382 17th May 2011 8:19pm
comports
Got one off fleabay - £75 obviously not tried anything yet as I don't have the other parts (still to order) but do get the "dot of death" in the instrument cluster. Obviously inconsistent mileage I guess. Hopefully will be able to get that coded once it's all up and running though. Ash
2016 SDV8 AB
Post #64392 17th May 2011 8:53pm
comports
Right - Light and rain sensor fitted to new screen. Looks great and lights up when I pull into the garage and turns off when I pull out (with a bit of a delay) but Censored if I can get the auto wipers to work.
Do you rekon it could be a coding thing and need to be activated.? Ash
2016 SDV8 AB
Post #65596 24th May 2011 6:42pm
dan_uk_1984
comports wrote:
Do you reckon it could be a coding thing and need to be activated.?
Until I had my issue with R/S I would say no. However In the last few days I found out that if your car is set to variable delay that is a specific setting. I'm working with Storey with his Rover All Comms to be able to code this.
I would say that a dealer "should" be able to enable this for you, however I would definitely check to ensure they are comfortable/competent at this, I'd hope to pay no more than 30 mins labour?
When Storey cracks the code for the RS then if I can help, I'll give you a shout.
D
Post #65602 24th May 2011 7:11pm
comports
Many thanks Dan - I can always rely on your knowledge to get me out of trouble. Much appreciated..Bow down
Auto lights work perfectly so that's a bonus. Thought it might just be plug and play but testing the wipers tonight I seem to just get intermittent (slow delay on pos 1) or intermittent (normal delay on pos 2)
No matter how much water the hose chucks at the screen no effect on't window... Grrrrrr.! Ash
2016 SDV8 AB
Post #65604 24th May 2011 7:15pm
comports
Actually - just sat here with the manual.... It suggests
Pos 1 intermittent/variable
Pos 2 Normal wipe - I get intermittent here as well..
Pos 3 Fast wipe
Pos 4 (down from off) flick wipe
How very strange. Ash
2016 SDV8 AB
Post #65608 24th May 2011 7:17pm
dan_uk_1984
Well, I hope my previous encouragement didn't get you into this trouble! Embarassed
I'm very excited about the auto lights though. I've finally found a LCM, but need to plug it in to see if I get the tamper dot.
Could you do a mini guide/write up on exactly what's needed for the retrofit? Maybe on the WiKi?
I guess there are three components:
New Rain/Light sensor
MK4 LCM
Light Switch with Auto setting
But is a new glass mount required or is it just the sensor?
Dan
Post #65609 24th May 2011 7:20pm
dan_uk_1984
Yup - that's the "Speed Step"
When you are stationary you get delay wiper on normal speed and slow wipe on fast speed Smile
Post #65611 24th May 2011 7:23pm
comports
Ah - That'll be it then. I was parked in the drive giving the car a quick shower at the time..
And yes - it was your fault that I started down the upgrade road - to be fair it was partly Daveo as well.. Thumbs Up
Will do a write up as well. Wish I took some photos now though.! Ash
2016 SDV8 AB
Post #65618 24th May 2011 7:34pm
dan_uk_1984
That's fine, take it all apart again!
I know, that Dave's a trouble maker!
I still say I've never seen a Vogue that doesnt have R/S!
Post #65623 24th May 2011 7:39pm
comports
Wink
Need to contact the mods I think. Just created the wiki page but seems I don't have permission to create any content (or too dumb to work out how to do it)
Will add it when I can. Ash
2016 SDV8 AB
Post #65625 24th May 2011 7:42pm
comports
Oh and be careful with the LCM. Mine said LCM - 4 on it but it did not work the auto features. The one I got from "the Bay" also said LCM - 4 and did work. This is what I bought in total.
LCM - 4 with Auto function from a 2007 FFRR £75.00 (ebay)
YDB200320 Light/Rain sensor £45.11
CTN000080PUY Mirror surround (left) £21.71
CTN000090PUY Mirror Surround (right) £21.71
YUD500880PUY Auto Light Switch £41.65
And of course a new screen !
Although I got a discount (not shown above) from the parts guy as I seem to be in there a lot lately. (and he plays snooker at the club where I play. Always good to mingle with the natives as he just offered me discount without asking.!) I think it was 20% Ash
2016 SDV8 AB
Post #65628 24th May 2011 7:54pm
dan_uk_1984
Is there a different mount on the glass? ie did you "need" the new screen?
Post #65630 24th May 2011 7:58pm
