Home > Maintenance & Mods (L322) > 4.4TDV8 P040D-00(2F) EGR temp sensor A - Where's the sensor?
Page 7 of 15 <123 ... 678 ... 131415>
GGDR
Yes Craig so wise, just not worth the hassle for that price. I completely got it even before I started..
If it was just a case of me I walking into a dealer and sticking to that kinda price, I'd do it. But I don't have a relationship with any LR dealer, I have a strong feeling if I would not get that price.
Or should I press on the book price side of the argument?
. Cheers, Greg
Post #487139 25th Aug 2018 5:39pm
Exactly what i hear often sir... Some do, some do-not!!!
Post #487140 25th Aug 2018 5:41pm
GraemeS
Australia
gonna_go_double_r wrote:
Nino, I think that is the other EGR sensor? The one on the EGR maybe?
Doesn't look at all familiar. Mike's diagram shows correct one.
Yes, Nino's pictures show the one in the EGR outlet pipe in the V, next to the oil cooler.
Post #487151 25th Aug 2018 8:51pm
GraemeS
Australia
Can you get to what appears to be a 2nd bolt retaining the rear heat-shield to loosen it in case that's enough to provide the needed clearance?
Would a small air ratchet be a suitable tool?
Actually, I would be bending the edge of the heat shield down using a big, long screw-driver and hammer.
Post #487153 25th Aug 2018 8:57pm
GGDR
Hi Graeme, yes I managed to get the little 8mm bolt out. I bent up the top shield but it wouldn't get out of the way enough. I like your second suggestion, if I could find/make something that would hook/hold on the edge while I banged it, I think it would give enough space for the socket.
Cheers, Greg
. Cheers, Greg
Post #487154 25th Aug 2018 9:11pm
GGDR
I think we can call that EGR temp sensor B
. Cheers, Greg
Post #487155 25th Aug 2018 9:12pm
GGDR
Just a bit of an update but no progress..
I've been underneath looking for alternate access for hands and tools. It seems a long way up from the underside, you can't even get a clear view of the sensor.
Which is weird because when you're looking in from the top it seems very far down. Why is it so far up from underneath too? Tardis engine bay.
The next thing I looked at while underneath was how hard the exhaust heat shield would be to remove. Answer: really hard.
So now I'm back to top access (also a b***h) and bending the heat shield out of the way as removing seems out of the question. Bending has also been so far impossible, I've even made up a couple of 'tools' - various shaped bits of metal to feed in a lever away the shield. No joy so far.
So progress is zero despite efforts. Not giving up yet, but it's definitely testing my resolve.
. Cheers, Greg
Post #488518 9th Sep 2018 6:27pm
gg2201
Had ours replaced whilst it was having some work done cleared the code must admit having looked at the access was glad someone else had the hassle Laughing 2011 4.4 TDV8 Autobiography
Post #490245 28th Sep 2018 8:33pm
Mine is in LR having the sensor/probe replaced! Amongst a heap of other works! Banging Head Banging Head Banging Head
Post #490246 28th Sep 2018 8:56pm
GGDR
I've tried several times but can't get it out. Not giving up but any tips from your guy GG????
Craig strange it's still occurring on 405s, would've thought they've revised the sensor.
. Cheers, Greg
Post #490247 28th Sep 2018 9:13pm
GGDR
GGs post also disproves the ghost code theory.
. Cheers, Greg
Post #490248 28th Sep 2018 9:15pm
No, the 405's suffer exactly the same as the 322's... I have 7 mates with 405's and every one has had this sensor/probe issue! Interestingly 4 have had to have the drain mod carried out too! Come on JLR Rolling Eyes
Post #490251 28th Sep 2018 9:35pm
GraemeS
Australia
Were any of the L405 original sensors the revised design or were they all the early design?
Post #490252 28th Sep 2018 9:42pm
Im guessing at some point JLR fitted the revised sensors at point of build... Just don't know when that was... Rolling Eyes
Post #490254 28th Sep 2018 9:49pm
GGDR
I even tried to make a tool to bend the exhaust heat shield - just to get the special socket on the bloody sensor!!!
I'll get the GoPro on a stick down there tomorrow and hatch a new plan....
I'm so keen to get it done and watch the code disappear like GG above! Thanks Craig for your advice - GG's experience proves your advice all along.
I have to say we are very fortunate to benefit from all your experience.
Thumbs Up Thumbs Up Thumbs Up Cheers, Greg
Post #490255 28th Sep 2018 9:51pm
