Home > Maintenance & Mods (L322) > 4.4TDV8 P040D-00(2F) EGR temp sensor A - Where's the sensor?
Page 3 of 15 <123 4 ... 131415>
GraemeS
Australia
With mine's engine idling for only a couple of minutes after start-up, all 4 of the EGT sensors that you showed are showing 100 deg C, although IIRC mine without a DPF only has 2 EGT sensors. Perhaps that's the minimum value displayed and that once the engine warms the true values will be shown. However as I'm about to tackle the oil cooler oil leak I don't want to get the engine hot.
Last time that I checked mine still had the P040D-00(2F) DTC.
Post #485673 11th Aug 2018 12:43am
GGDR
100 degrees is the minimum value I believe Graeme
. Cheers, Greg
Post #485678 11th Aug 2018 8:21am
cass
Just checked mine, same fault code and same 100 degree reading as yours.
Post #485691 11th Aug 2018 10:28am
cass
Should probably add I thought I’d added a photo of the readings but my IT skills have failed me
I’ve had that fault code since I bought it 2 years ago and never had a DPF problem,
Perhaps I’ve just been lucky?
Post #485693 11th Aug 2018 10:42am
nino_nino
temperature on the bank 2 sensor 1 will go above 100 C only if the engine is spinning over 23~25 hundred rpm. in the pic. you can see temp. have gone up so the sensor is working. i have had it. go up ove 280C while the revs are kept up above 23 hundred rpm,s.
Nino,
Post #485696 11th Aug 2018 11:15am
GGDR
Ok cheers cass - was your engine hot?
Nino I'm no expert but shouldn't th manifold read the highest of all?
. Cheers, Greg
Post #485697 11th Aug 2018 11:48am
GraemeS
Australia
In that case that sensor must be the one in the exhaust pipe from the secondary turbo on the left side of the engine.
I wonder if bank1 is referring to the primary exhaust path and bank2 referring to the secondary exhaust path rather than cylinder banks.
Post #485698 11th Aug 2018 11:52am
GraemeS
Australia
Euro 4 only has temp sensor in left manifold and oxygen sensor after primary turbo - only measuring EGT in 1 manifold (no need to measure both). Bank1 sensor1?
Euro 5 has temp sensor in left manifold (bank1 sensor1?), oxygen then temp sensor between primary turbo and the cat (bank1 sensor2?) and another between the cat and the DPF (bank1 sensor3?) and another between the secondary turbo and the DPF (bank2 sensor1).
Post #485699 11th Aug 2018 12:10pm
GGDR
So Graeme this shows my 4 EGT readings.
There a 3 on Bank 1 and the one I question on Bank 2.
See this from when I regenerated my DPF:
Bank 1 Sensor 2 must be the DPF. Does this marry with your count of the sensors?
I need to get unplugging to find out for sure.
. Cheers, Greg
Post #485701 11th Aug 2018 1:03pm
GGDR
Nino do you have the error?
. Cheers, Greg
Post #485703 11th Aug 2018 1:50pm
GGDR
I'm also wondering if Pat @ Gap might know which one is which one...
. Cheers, Greg
Post #485704 11th Aug 2018 1:51pm
cass
Yes it was hot, they all read 100 when it was cold.
Post #485710 11th Aug 2018 2:18pm
Baltic Blue
Your I T skills are twice as good than earlier Rolling with laughter Rolling with laughter
But your DPF soot level is perfect Thumbs Up Thumbs Up
Post #485714 11th Aug 2018 2:37pm
nino_nino
I have, it was there first time i checked with IIDTool +/_ 100K km now.
Nino,
Post #485715 11th Aug 2018 3:46pm
GGDR
Nino I think you have disproved part of my theory probably then that sensor reads temp post turbo number two. Which makes sense baciase all readings i've taken are under 2k revs. Cheers, Greg
Post #485725 11th Aug 2018 5:35pm
