![]() | Home > Maintenance & Mods (L322) > 4.4TDV8 P040D-00(2F) EGR temp sensor A - Where's the sensor? |
kokamagi Member Since: 31 May 2020 Location: Viljandi Posts: 84 ![]() ![]() ![]() |
Yes the readings seem to be very healthy. Might be intermittent problem. Maybe check the wiring and connectors first, wiggle them around. I believe B1S3 is reffering to the same sensor on both engines.
minim Member Since: 15 Mar 2024 Location: Bergen Posts: 35 ![]() ![]() ![]() |
thanks. I'll have a look there. I checked the TDV6 manual now and it's a bit more confusing as it says Bank 1 sensor 3, on the error code side it says bank 2 sensor 2 and it describes it as the sensor post catalytic converter.
On your screenshot you had DTC P242A-00, but from the manual you are looking at another DTC P242A-22.
The 00 doesn't show in the 3.0 tdv6 manual so I used that screenshot since it's talking about the same sensor (b1s3) and is mixing it with the other. All the 242 is mentioning b1s3 and have the same mixup in the description to the right.
I added some pictures from my normally working 4.4tdv8 system to my last post and explanation why b2s1 is reading 100.
GregPrice80 Member Since: 25 Jan 2024 Location: Exmouth Posts: 44 ![]() ![]() ![]() |
Has anyone experienced this fault code along with an occasional yellow restricted performance on starting the car? And did changing the sensor get rid of the warning? 2010 Range Rover 4.4TDV8 Autobiography Black Edition
Thank you for the info. It's just like you say on the throttle with that sensor after the turbo. So then I got 4 working sensor and I can only assume that the one earlier at zero was just not used on my car. The fault is gone for now so I'll inspect wires and unplug senors to test next time as it seems unclear what sensor is what still. I'll check with gap also.
FrankRizzo Member Since: 27 Aug 2012 Location: Frankfurt am Main Posts: 218 ![]() ![]() ![]() |
I've just purchased my GAP tool (IIDControl 4.2.11 Build 168 Android - IIDTool BT V4.0 B3998) and this is the only fault that is recurring on my vehicle. On the first code read there were a lot of codes from July when my MD fitted a new battery and alternator.
