Home > Maintenance & Mods (L322) > 3.6 TDv8 / ZF6HP26 Gearbox Oil Change |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6414 |
@ Highroller, don't forget to tap out the threads .
16th Aug 2018 3:34pm |
unsolicited Member Since: 30 May 2016 Location: Bucks Posts: 128 |
My threads were all perfect & had zero problems removing or replacing the bolts. Of course condition will vary with usage/environment. They will probably be OK. |
17th Aug 2018 5:12pm |
Highroller Member Since: 18 Jul 2016 Location: Hampshire Posts: 565 |
Update so far. Oil drained & as per Pawl's comments good to see a reddish colour with no debris on the magnets (Removed 5.5 ltrs).
19th Aug 2018 4:56pm |
Yes, when you are ready with bottles of Lifeguard under the car and your pump, and you have got as much in as you can with the engine off, start the car, then dive under and start pumping. You also need to monitor the transmission oil temp, as the fluid level check should be done at between 30 and 50 degrees (not below or above). As soon as it starts dribbling out again, get into the drivers seat, foot hard on footbrake, and slowly work your way through the gears, 3 seconds in each. Also go across to command shift (manual) and up into 3rd then down to 2nd and 1st ( I got quite a clunk when going into 1st!). Once done, back underneath and pump some more. When it starts dribbling again put filler plug back in. Job Done .
19th Aug 2018 6:24pm |
You also don't have that much time before the oil temperature moves out of range (may be better with the diesel, but the temperature rises quickly with the supercharged).
20th Aug 2018 4:46pm |
All done & no issues. Went through all the gear selections without any clunks etc. Drove ok without any issues. Very pleased. |
20th Aug 2018 4:59pm |
Danwilderspin Member Since: 15 Jun 2016 Location: Cambridgeshire Posts: 2215 |
Can anyone tell me if the Mobil 1 oil for the 5hp24 would cause this box a problem? I bought 20 litres of the stuff for my old 4.4 and have a good 10 l left and it wasn’t cheap Current stable:
4th Apr 2020 9:53am |
ur20v Member Since: 19 Feb 2019 Location: None Posts: 634 |
My opinion is if it’s the correct spec then it’s fine, others may have a different opinion. Oil make debates are always interesting’ and almost always based on antidotal evidence or pure conjecture and bias to a particular brand.
4th Apr 2020 10:35am |
The 5HP24 has different oil spec I'm afraid. I wouldn't use anything apart from the correct ZF lifeguard fluid. |
4th Apr 2020 10:45am |
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6740 |
I don’t think they would do this unless you specifically requested it, as they say it’s sealed for life.
4th Apr 2020 10:53am |
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1783 |
DONT put it into a 6HP box |
4th Apr 2020 12:00pm |
Ok so I have to buy 7 1 litre bottles? I see on eBay kits with the plastic filter for £190 all in with 7 bottles of zf?
4th Apr 2020 1:35pm |
Febi oil is decent stuff. Used it a few times over the years when I've struggled for Ravenol stuff |
4th Apr 2020 5:11pm |
appj62 Member Since: 07 Aug 2013 Location: Cheshire Posts: 424 |
Had my transmission oil changed over 3 years and 15000 miles ago at my local indy. Noticed in the last year or so that gearbox was reluctant to change up when starting from cold but otherwise OK. Also noticed more recently that getting oil onto drive but not excessively. Whilst underneath the car, sorting out my rear subframe, noticed a drip from the gearbox drain plug.
16th Apr 2020 6:22pm |
