Home > Maintenance & Mods (L322) > Can anyone recommend snow foam that actually works |
nar53 Member Since: 04 Nov 2015 Location: Le Mans Posts: 120 |
I've tried the Karcher stuff which leaves me totaly underwhelmed which makes me wonder if any of it is any good.
24th Jan 2018 5:39pm |
At the risk of being ostracized I must ask why a question about Snow Foam would be moved to a vehicle specific forum. Surely snow foam isn’t used exclusively by the owners of the L322! |
24th Jan 2018 6:33pm |
rjff Member Since: 28 Oct 2017 Location: Cambridgeshire Posts: 1196 |
Hi nar53
24th Jan 2018 6:36pm |
SoggyBottoms Member Since: 05 May 2012 Location: Northants. Posts: 457 |
not sure I'd do that. it'll have crap in it and scratch the paint |
24th Jan 2018 8:04pm |
TDSIX Member Since: 18 Feb 2017 Location: Stirlingshire Posts: 210 |
My process..
24th Jan 2018 11:10pm |
Thanks for the input Guys.
25th Jan 2018 10:04pm |
John w Member Since: 14 Jan 2018 Location: Cranleigh, Surrey Posts: 439 |
I'm watching this post with interest.
25th Jan 2018 11:12pm |
rar110 Member Since: 09 Aug 2014 Location: Brisbane, Australia Posts: 1119 |
Most foams will strip off the wax.
25th Jan 2018 11:40pm |
Scottyav Member Since: 11 Feb 2013 Location: Cannock Staffordshire Posts: 1204 |
I snow foam with this as is colour less and won’t mark plus ph free and I’ve valeted a lot over the years, muck drops off mine but it’s got a fantastic glaze and shine but if I do a pals I still use a soapy mit after covering it in the foam as when it’s sprayed on it’s s lot easier to give the car a quick wash with the glove ‘‘tis was £25 off the bay delivered eBay Item No. 111975654784
26th Jan 2018 9:24am |
verydisco Member Since: 10 Dec 2009 Location: UK/US Posts: 2952 |
What I found makes the foam work best is to use hot water from the kettle, mix it in the foam lance bottle and off you go! l=Oo\________/oO=l l:OolΞΞΞΞΞΞΞloO:l
26th Jan 2018 3:59pm |
olliecat2 Member Since: 30 Jan 2018 Location: FLINTSHIRE Posts: 13 |
Auto bright direct, it dwells on car as a thick white foam for over twenty minutes and you can buy spray dispenser to fit pressure washer as well and its a solid bit of kit with brass fittings for less than £50 sometimes with a litre sample foam |
31st Jan 2018 9:39pm |
Thanks for all the suggestions but I'm thinking I'll just stick to using a bucket of soapy water & a sponge. At least I know it works. |
31st Jan 2018 10:31pm |
m@ttsFF Member Since: 12 Dec 2017 Location: Surrey Posts: 329 |
Not as well as the 2 bucket approach ....
31st Jan 2018 10:39pm |
Consider buying a good quality wash and wax detergent. You can pick up a 1lt bottle of detergent on special for a reasonable price. I will often buy a couple if heavily discounted.
31st Jan 2018 10:49pm |
