![]() | Home > Range Rover P38 > My P38 |
Dolphinboy Member Since: 07 Dec 2009 Location: Bristol Posts: 3210 ![]() ![]() ![]() |
Gosh what a great tale! I borrowed my mate's 2000 4.6 HSe to drive to London for a few days and it was awesome. Have to say when they're good.... They're the best!!
Sandyt Member Since: 07 Nov 2013 Location: Wraysbury Windsor Posts: 2276 ![]() ![]() ![]() |
Mine is going in for some work to get through the mot I blew the head gasket 4 years ago so it has been in the garden. I replaced the head gaskets in the summer and the exhaust needs a lot of TLC internally to get rid of the mould
Will post a couple of pics later |
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3252 ![]() ![]() ![]() |
Trigger's broom? ![]() ![]() 2008 Stornoway Grey 3.6 Tdv8 Vogue 2005 TD6 Java Black Vogue - Written off!! GAP iiD BT 2003 Discovery TD5 Auto, Nanocom Evolution - gone to a new home! MasseyFerguson 152 - No electronics!! - Sold |
Sure there were other parts as well - its in the garden next to my classic and the FF will prob end up there when \i change it SWmbo has told me they are not coming with us to France so I said "Going on your own are you?" that prompted an interesting reply |
stevebrookman Member Since: 08 Jan 2010 Location: South Wales Posts: 50 ![]() |
Still on there! |
MOT passed again!
Thanks!
kooky_guy Member Since: 25 Nov 2011 Location: Sandhurst, Berkshire Posts: 386 ![]() ![]() ![]() |
Are you sure it's the windscreen? A common failure point is a seam under the top trim piece (drivers side) - it looks like the original design didn't make the panels quite big enough so they filled the gap with seam sealer that eventually breaks down and pinhole leaks form. A quick squirt of silicone sealant fixes it. Seems to be affecting a few of them now. Getting the top trim off and back on again without bending it is a bit tricky unless you take one of the pillar trims off as well. The removal procedure is in Rave, but it involves the use of a credit card. Worth a look anyway! 2010 4.4 TDV8 Vogue SE |
Thanks Kooky_Guy,
