Home > Range Rover P38 > My P38
stevebrookman
My P38
Had my 1999 4.6 HSE for 11 years now.
Have been very lucky-it's let me down once in this time. The wife didn't shut the boot properly, the battery drained and the BeCM lost synch with the engine ECU. Cost £200 to get it sorted. Luckily it was under the car port at the time.
Here's it being used as a kennel whilst kaput.
I've replaced the exhaust a couple of times, new tyres and had the air suspension air bags changed several years ago. Also replaced a tired suspension compressor this year-so overall-not too bad!
The battery is 12 years old and still performing well!
It is starting to fail, I've a leak from the windscreen for ages which causes a lot of condensation, recently the sunroof has started to play up and after having the BeCM I need to get the radio code.
Have been looking for several years to replace it with a Supercharged Full Fat, but it's always sailed through the MOT.
As I look out the window-we have heavy snow-as I'm always well organised (not)-the bloody MOT is up in three days!
So onwards in the search for a Supercharged-was looking at getting a 5.0 but will most probably settle on a 4.2. Must be Grey though!
Steve
Post #460174 10th Dec 2017 9:07am
Dolphinboy
United Kingdom 2015 Range Rover Autobiography SDV8 Baltic Blue
Gosh what a great tale! I borrowed my mate's 2000 4.6 HSe to drive to London for a few days and it was awesome. Have to say when they're good.... They're the best!!
Bow down Thumbs Up
Post #460203 10th Dec 2017 1:08pm
Sandyt
Mine is going in for some work to get through the mot I blew the head gasket 4 years ago so it has been in the garden. I replaced the head gaskets in the summer and the exhaust needs a lot of TLC internally to get rid of the mould
In the time I have had it 17 yrs its a 1998 it has had 3 engines two front wings drivers door tailgate 4 rads new wiper motor new airbags all round new compressor pump changed all the bushes and it has done 186k miles so it will be good to get it back on the road.
Post #460293 11th Dec 2017 8:29am
Sandyt
Will post a couple of pics later
Post #460294 11th Dec 2017 8:31am
Weegie
Trigger's broom? Very Happy Very Happy John
GAP iiD BT
Post #460295 11th Dec 2017 8:33am
Sandyt
Sure there were other parts as well - its in the garden next to my classic and the FF will prob end up there when \i change it SWmbo has told me they are not coming with us to France so I said "Going on your own are you?" that prompted an interesting reply
Post #460296 11th Dec 2017 8:37am
Sandyt
Re: My P38
Good to see it is still going strong used to see you on Landyzone
Steve
Post #460297 11th Dec 2017 8:39am
stevebrookman
Still on there!
Post #460356 11th Dec 2017 12:25pm
stevebrookman
MOT passed again!
Hasn't failed since I've had it.
May now get a new windscreen to stop the leak.
I've also got to replace the boot release solenoid-got one coming for £15.
Steve
Post #460912 15th Dec 2017 7:27am
Sandyt
Thumbs Up Thumbs Up Thumbs Up Thumbs Up
Post #460922 15th Dec 2017 10:10am
stevebrookman
Thanks!
It's the 11th MOT without fail since I've had it.
Here it is earlier this year
Post #461115 17th Dec 2017 9:27am
kooky_guy
MOT passed again!
Steve
Are you sure it's the windscreen? A common failure point is a seam under the top trim piece (drivers side) - it looks like the original design didn't make the panels quite big enough so they filled the gap with seam sealer that eventually breaks down and pinhole leaks form. A quick squirt of silicone sealant fixes it. Seems to be affecting a few of them now.
Getting the top trim off and back on again without bending it is a bit tricky unless you take one of the pillar trims off as well. The removal procedure is in Rave, but it involves the use of a credit card.
Worth a look anyway! 2010 4.4 TDV8 Vogue SE
Post #461231 18th Dec 2017 9:44am
stevebrookman
Thanks Kooky_Guy,
The Range Rover has gone in for a "mini restoration" with a very good local specialist. New headlining, door lock, majority of security removed, air con fixed, height sensor changed, windscreen removed and resealed, new battery (one on there is 14 years old), boot release fixed, MOT, full service, gearbox flushed. Should be good for another 12 years!
Steve
Post #525031 16th Aug 2019 8:12am
