Home > Technical (L322) > Heating slow? |
GAC23 Member Since: 27 Nov 2013 Location: Herts Posts: 670 |
Because it was cold yesterday - I'm sure you noticed - I ran the FBH (using the remote). Once running the car warmed up nice and quickly. Then found this in the Wiki: http://www.fullfatrr.com/wiki/FBH On Td6 models, additional heating reduces the heater warm-up time and is also used to maintain heater performance throughout the drive cycle. On V8 models, additional heating is only used to reduce the heater warm-up time at the beginning of the drive cycle, and only occurs if parked heating is already active when the engine starts. If I've read it right ... Your old TD6 would have always used the FBH (when required). But my TDV8 needs me to have switched the FBH on before I jump in and start the car. Going to have to test this now What do I put here then? |
11th Dec 2017 11:35am |
bembo449 Member Since: 26 Jul 2017 Location: lincolnshire Posts: 803 |
my temp gauge never gets over a 1/4 really , from what ive read it should be at 12 o'clock , car gets hot enough though |
11th Dec 2017 1:17pm |
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3657 |
^ thermostat stuck open, more likely the EGR one! Yesterday I couldn't spell Engineer... Today I are one!
11th Dec 2017 1:19pm |
can it be tested then pal ?? |
11th Dec 2017 1:20pm |
I'm not sure I know it's a sealed unit and most peeps just change it as a lump... I think you can blank it too! Try a search on 'EGR thermostat' Yesterday I couldn't spell Engineer... Today I are one!
11th Dec 2017 1:24pm |
ok thanks pal , I have a remap with EGR delete so its not like I need it lol |
11th Dec 2017 1:26pm |
Ian928 Member Since: 16 Aug 2016 Location: Kristiansund Posts: 78 |
I har the same thing happening, I believe it was because I filled the system with water temporarily to check after repairing a leak. I found that the seals had swollen, probably because of osmosis because I filled the system with water. It would be interesting to hear if others have had experiences with slow or no heat after filming with water or Even changing Concentration of coolant (may happen when changing coolant). 2006 Supercharged |
11th Dec 2017 4:21pm |
I need to look at this valve and the EGR stat asap , see why rory doesn't get that hot |
11th Dec 2017 5:55pm |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3977 |
Can you get hold of an infrared thermometer and check what your engine temperature is before you start changing things? |
11th Dec 2017 6:32pm |
erm , I very much doubt it pal |
11th Dec 2017 8:31pm |
ohuntsman Member Since: 21 Mar 2016 Location: Surrey Posts: 337 |
You can pick them up for a fiver |
11th Dec 2017 8:35pm |
oh right , wouldn't surprise me if there is an App available that does it too ?? |
11th Dec 2017 8:37pm |
https://www.ebay.co.uk/itm/UK-Non-Contact-...Sw3WxaC91q
11th Dec 2017 8:40pm |
thanks miggit |
11th Dec 2017 8:43pm |
