Home > Technical (L322) > Heating slow?
GAC23
United Kingdom 2015 Range Rover Vogue SE SDV8 Indus Silver
miggit wrote:
I believe that is what the FBH, or, fuel burning heater is supposed to cure... The question is have you got one and is it working? My old TD6 would be blowing warm air after 7 or 8 minutes, even in the depths of winter.
Because it was cold yesterday - I'm sure you noticed Smile - I ran the FBH (using the remote).
Once running the car warmed up nice and quickly.
Then found this in the Wiki: http://www.fullfatrr.com/wiki/FBH
On Td6 models, additional heating reduces the heater warm-up time and is also used to maintain heater performance throughout the drive cycle. On V8 models, additional heating is only used to reduce the heater warm-up time at the beginning of the drive cycle, and only occurs if parked heating is already active when the engine starts.
If I've read it right ...
Your old TD6 would have always used the FBH (when required).
But my TDV8 needs me to have switched the FBH on before I jump in and start the car.
Going to have to test this now Smile What do I put here then?
Post #460336 11th Dec 2017 11:35am
GAC23
nino_nino wrote:
GAC23, do you have wheel in the in the center console turned to heat(all red marks). do full left full right turn and see if it helps.
Thanks for the tip. Going to try it later. What do I put here then?
Post #460337 11th Dec 2017 11:37am
bembo449
United Kingdom 2002 Range Rover Vogue Td6 Adriatic Blue
my temp gauge never gets over a 1/4 really , from what ive read it should be at 12 o'clock , car gets hot enough though
Post #460367 11th Dec 2017 1:17pm
miggit
^ thermostat stuck open, more likely the EGR one! Yesterday I couldn't spell Engineer... Today I are one!
Post #460368 11th Dec 2017 1:19pm
bembo449
can it be tested then pal ??
Post #460370 11th Dec 2017 1:20pm
miggit
I'm not sure Embarassed I know it's a sealed unit and most peeps just change it as a lump... I think you can blank it too! Try a search on 'EGR thermostat' Thumbs Up Yesterday I couldn't spell Engineer... Today I are one!
Post #460373 11th Dec 2017 1:24pm
bembo449
ok thanks pal , I have a remap with EGR delete so its not like I need it lol
Post #460374 11th Dec 2017 1:26pm
Ian928
Norway 2006 Range Rover Supercharged 4.2 SC V8 Java Black
Sandyt wrote:
...acts as a diverter but if stuck half way restricts heat coming from the either source so it takes an age to get heat into the cabin heat exchanger
I har the same thing happening, I believe it was because I filled the system with water temporarily to check after repairing a leak. I found that the seals had swollen, probably because of osmosis because I filled the system with water.
It would be interesting to hear if others have had experiences with slow or no heat after filming with water or Even changing Concentration of coolant (may happen when changing coolant). 2006 Supercharged
Post #460386 11th Dec 2017 4:21pm
bembo449
I need to look at this valve and the EGR stat asap , see why rory doesn't get that hot
Post #460393 11th Dec 2017 5:55pm
Can you get hold of an infrared thermometer and check what your engine temperature is before you start changing things?
Post #460397 11th Dec 2017 6:32pm
bembo449
erm , I very much doubt it pal
Post #460415 11th Dec 2017 8:31pm
ohuntsman
United Kingdom 2002 Range Rover Vogue 4.4 V8 Zambezi Silver
You can pick them up for a fiver Thumbs Up
Post #460417 11th Dec 2017 8:35pm
bembo449
oh right , wouldn't surprise me if there is an App available that does it too ??
Post #460418 11th Dec 2017 8:37pm
miggit
https://www.ebay.co.uk/itm/UK-Non-Contact-...Sw3WxaC91q
Post #460420 11th Dec 2017 8:40pm
bembo449
thanks miggit Thumbs Up
Post #460421 11th Dec 2017 8:43pm
