Home > Technical (L322) > Heating slow? |
fisha Member Since: 25 Sep 2009 Location: Scotland Posts: 1371 |
It's a big block of metal and modern diesels are quite efficient such that they don't waste much heat ... So it will take a while.
9th Dec 2017 2:41pm |
Paul thornton Member Since: 23 Sep 2017 Location: Lancashire Posts: 545 |
What's the temp gauge reading ?
9th Dec 2017 3:06pm |
GAC23 Member Since: 27 Nov 2013 Location: Herts Posts: 670 |
Temp gauge at about 1/4 and still not flooding the cabin with heat.
9th Dec 2017 3:59pm |
Needs to be at the half way mark really. Does it ever reach half way or does it stay at a quarter? |
9th Dec 2017 4:04pm |
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3657 |
I believe that is what the FBH, or, fuel burning heater is supposed to cure... The question is have you got one and is it working? My old TD6 would be blowing warm air after 7 or 8 minutes, even in the depths of winter. Yesterday I couldn't spell Engineer... Today I are one!
9th Dec 2017 5:23pm |
It does get to half way - and heats the cabin then. Just thought it was slow to warm up inside. What do I put here then? Last edited by GAC23 on 9th Dec 2017 5:46pm. Edited 1 time in total |
9th Dec 2017 5:44pm |
Do have FBH and - as far as I can tell - it works. Will have to do a more scientific test I think. What do I put here then? |
9th Dec 2017 5:45pm |
Thanks both for your comments. What do I put here then? |
9th Dec 2017 5:46pm |
With the TD6 it's hidden under the battery, and even with the engine running you can hear it when you get close to the near side gill.... sounds like a jet engine is lurking there! The other giveaway is the exhaust is there too, under the car, and you can often see steam rising from just behind the wheel... but only on days that you can see your breath!! Yesterday I couldn't spell Engineer... Today I are one!
9th Dec 2017 5:49pm |
Thank you. I’ve run the FBH some mornings to defrost the car and warm it a little.
9th Dec 2017 6:06pm |
So if you pre heat the car there is no problem?
9th Dec 2017 6:10pm |
Sandyt Member Since: 07 Nov 2013 Location: Wraysbury Windsor Posts: 2265 |
Although mine is petrol I had a recent problem with the heater and now mine produces warm air within a couple of minutes after starting.On the diesels the fuel burning heater should kick in if the temp is below 14c to assist with warming up.
10th Dec 2017 3:59am |
nino_nino Member Since: 29 Mar 2015 Location: pocitelj Posts: 690 |
GAC23, do you have wheel in the in the center console turned to heat(all red marks). do full left full right turn and see if it helps.
10th Dec 2017 10:07am |
dolph34 Member Since: 14 Sep 2015 Location: Kildare Posts: 1724 |
Mine takes about 5 mins until I'm toasty 2015 4.4 AB
10th Dec 2017 12:57pm |
