Home > Technical (L322) > Bonnet catch stuck shut......Help Please |
Johnsd1v8 Member Since: 06 Jul 2017 Location: Cheshire Posts: 190 |
Could you remove the arch liner pal would you be able to reach up and try manualy work the catch by hand or screwdriver |
31st Jul 2017 3:21pm |
Dreckly Member Since: 16 Apr 2015 Location: Truro, Cornwall Posts: 47 |
Hi Johnsd1v8.
31st Jul 2017 3:33pm |
Freddie The Fish Member Since: 13 Apr 2017 Location: Bedfordshire Posts: 115 |
Had a similar problem when I changed my bonnet, didn't line the catches up properly and shut it prematurely. One catch was released but not the other. I just gave it a hefty pull with a slight wiggly riight where the catch was and it popped it. I used bits of card over the holes to align it after that. (Massive panic moment though) |
31st Jul 2017 4:20pm |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6408 |
Word to the wise:
31st Jul 2017 5:43pm |
Thanks for that Freddie. I'm glad it's not just me.
1st Aug 2017 4:08pm |
dingg1 Member Since: 29 Jun 2013 Location: PORTUGAL Posts: 1340 |
happened to me when I put a new front end on
1st Aug 2017 5:05pm |
Oops forgot to add I had someone holding up the release catch... try and and don't be shy with the pulling, get your fingers as near to the catch as possible. |
1st Aug 2017 7:24pm |
Thanks for your input Guys.
1st Aug 2017 9:45pm |
The bonnet needs to be shifted to the left/right. Can someone pull the lever while you push on the side of the bonnet to try and shift it over enough to release? |
2nd Aug 2017 8:03am |
Hi Dan,
2nd Aug 2017 2:16pm |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3973 |
With someone pulling the release cable and yourself pressing down hard where the catch is try repeatedly banging the bonnet hard with you fist directly above the catch, you never know. |
2nd Aug 2017 6:33pm |
Hi Nicedayforit,
3rd Aug 2017 7:51pm |
Can you get a socket (Alan key) on it to undo it ? Although they have a locking nut I think it should still turn if you can get on it ? |
3rd Aug 2017 8:14pm |
Got the !!!
4th Aug 2017 3:34pm |
