![]() | Home > Technical (L322) > Bonnet catch stuck shut......Help Please |
Johnsd1v8 Member Since: 06 Jul 2017 Location: Cheshire Posts: 190 ![]() ![]() ![]() |
Could you remove the arch liner pal would you be able to reach up and try manualy work the catch by hand or screwdriver |
Dreckly Member Since: 16 Apr 2015 Location: Truro, Cornwall Posts: 47 ![]() ![]() ![]() |
Hi Johnsd1v8.
Freddie The Fish Member Since: 13 Apr 2017 Location: Bedfordshire Posts: 115 ![]() ![]() ![]() |
Had a similar problem when I changed my bonnet, didn't line the catches up properly and shut it prematurely. One catch was released but not the other. I just gave it a hefty pull with a slight wiggly riight where the catch was and it popped it. I used bits of card over the holes to align it after that. (Massive panic moment though) |
Word to the wise:
Thanks for that Freddie. I'm glad it's not just me.
dingg1 Member Since: 29 Jun 2013 Location: PORTUGAL Posts: 1356 ![]() ![]() |
happened to me when I put a new front end on
Oops forgot to add I had someone holding up the release catch... try and and don't be shy with the pulling, get your fingers as near to the catch as possible. |
Thanks for your input Guys.
The bonnet needs to be shifted to the left/right. Can someone pull the lever while you push on the side of the bonnet to try and shift it over enough to release? |
Hi Dan,
With someone pulling the release cable and yourself pressing down hard where the catch is try repeatedly banging the bonnet hard with you fist directly above the catch, you never know. |
Hi Nicedayforit,
Can you get a socket (Alan key) on it to undo it ? Although they have a locking nut I think it should still turn if you can get on it ? |
Got the |
