Home > Technical (L322) > L322 weird brake binding issue then HDC inactive...
bogie
Got a strange one over the last few weeks and seems to be happening more often
So starts as normal and when you pull away, some noises and hesitation, like leaving handbrake on, but it seems to be from different wheels, rather than all 4 simultaneously or just rear
After 20-30metres or a few secs of driving it clears itself, then throws up the HDC inactive and then Air suspension inactive messages
Stop car, restart, messages clear sometimes...maybe it wont do it for a day or two
sometimes, 30 mins later, start car to go somewhere, and it does the same routine
started doing it in the bad weather, so I put it down to sticking brakes, but its getting more frequent
It feels a bit like the brakes are binding, like when you have sticky discs n pads after rain on some sportscars
Any ideas? could it be the ABS sticking the brakes on ...or just sticky handbrake maybe ?
it was serviced 6 months/4K miles ago and no recommendations on pads/discs or anything....
TIA cheers
bogie
Post #45683 12th Jan 2011 11:19am
Jem0911
United Kingdom 2015 Range Rover Vogue SE SDV8 Corris Grey
The only time I had that was when MrsJem activated the HDC by mistake.
Felt like I had run over something as differing wheels braked.
I noticed and turn the system off before confusing the car.
I guess its an HDC fault if its constantly happening. 15MY SDV8 Vogue SE
Post #45686 12th Jan 2011 11:22am
a battery thats not 100% throws up so many problems on the l322 mainly the dashboard errors...this would be my first port of call ..the RR has brake shoes for the handbrake and these aren't used much so when the hand brake is applied it might stick on one or both sides especially with this cold and wet weather...
Post #45689 12th Jan 2011 11:28am
dan_uk_1984
My initial thoughts:
The car cant tell if the brakes are binding due to a mechanical fault, so the error messages are due to diagnosis of a Software fault.
The fact that the brakes are releasing after a set time would in theory rule out a physical problem (seized calliper, stuck stone, guide pins)
The link between EAS and HDC is vehicle speed (they both need to know how fast the car is going) - they both determine the vehicle speed from the ABS sensors, via the ABS ECU.
No actual solution for you above sorry, but maybe looking at what systems effect others will lead you to the dodgey component.
Personally in this situation I would visit a LR dealer or specialist that can read the codes (assuming it is recording them properly)
Dan
Post #45690 12th Jan 2011 11:30am
bogie
yeah, I think its something HDC related as that uses the brakes ...
best get it into local specialist
thanks guys cheers
bogie
Post #45697 12th Jan 2011 12:30pm
IanV8
Scotland 2011 Range Rover Vogue SE TDV8 Santorini Black
I have had something similar recently and it feels as if the traction control is trying to come in.
I have been getting HDC inop & air suspension inop messages whilst driving along but I have noticed that the speedo drops to 0 then starts to read again. The error messages normally go away after a stop and ignition reset but not always.
RAVE states that speed is measured by the rear left sensor so had a quick look at both my rears at the weekend, nothing obvious no damaged wires or loose sensors.
Ian
Post #45729 12th Jan 2011 1:54pm
bogie
I think its going to be one of those quirky bugs where you replace on bit at a time in chain until it goes away Smile
...really must buy my own pukka fault reader this month to save the trips to the garage..... cheers
bogie
Post #45779 12th Jan 2011 5:24pm
bogie
ok, just in case anyone else gets similar. Turned out to be front r/h wheel speed sensor fault, so replaced, reset and so far so good
fingers crossed an easy fix Smile cheers
bogie
Post #46165 15th Jan 2011 2:57pm
TommyZoom
2003 Range Rover Vogue SE Td6 Zambezi Silver
I'm not sure if this is related or not, but any thoughts would be greatly received! I pulled out of the car park at work, put my foot down to pull away and the car started making this grinding noise from the brakes, almost as if the HDC or ABS was kicking in. Long story short - 5 hours! RAC think it's the ABS ECU or the pistons on the brake calipers. Current: 2003 Range Rover Vogue SE Auto TD6, 2004 Mercedes C270 CDi Saloon Elegance SE
Gone: 1966 Land Rover Series 2a, 1999 Mercedes A170, 1998 Vauxhall Omega Estate 2.5 V6
Post #249088 18th Mar 2014 10:43pm
mjdronfield
Have a read here, and my link from within it.
http://www.fullfatrr.com/forum/topic24105.html
Sound similar ? 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #249117 19th Mar 2014 8:45am
TommyZoom
That sounds very familiar! The only difference is, I had no warning lights. The DSC lit up for a moment, but no lights otherwise. Current: 2003 Range Rover Vogue SE Auto TD6, 2004 Mercedes C270 CDi Saloon Elegance SE
Post #249138 19th Mar 2014 10:47am
