![]() | Home > Technical (L322) > L322 weird brake binding issue then HDC inactive... |
Jem0911 Member Since: 07 Jan 2010 Location: East Northants Posts: 357 ![]() ![]() ![]() |
The only time I had that was when MrsJem activated the HDC by mistake.
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35633 ![]() ![]() |
a battery thats not 100% throws up so many problems on the l322 mainly the dashboard errors...this would be my first port of call ..the RR has brake shoes for the handbrake and these aren't used much so when the hand brake is applied it might stick on one or both sides especially with this cold and wet weather... |
My initial thoughts:
bogie Member Since: 06 Nov 2010 Location: Notts/Sth Yorks/Lincs border Posts: 208 ![]() ![]() ![]() |
yeah, I think its something HDC related as that uses the brakes ...
IanV8 Member Since: 14 Jan 2010 Location: Dunfermline Posts: 502 ![]() ![]() ![]() |
I have had something similar recently and it feels as if the traction control is trying to come in.
I think its going to be one of those quirky bugs where you replace on bit at a time in chain until it goes away |
ok, just in case anyone else gets similar. Turned out to be front r/h wheel speed sensor fault, so replaced, reset and so far so good
TommyZoom Member Since: 23 May 2013 Location: Newbury, Berkshire Posts: 11 ![]() ![]() |
I'm not sure if this is related or not, but any thoughts would be greatly received! I pulled out of the car park at work, put my foot down to pull away and the car started making this grinding noise from the brakes, almost as if the HDC or ABS was kicking in. Long story short - 5 hours! RAC think it's the ABS ECU or the pistons on the brake calipers. Current: 2003 Range Rover Vogue SE Auto TD6, 2004 Mercedes C270 CDi Saloon Elegance SE
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7906 ![]() ![]() ![]() |
Have a read here, and my link from within it.
That sounds very familiar! The only difference is, I had no warning lights. The DSC lit up for a moment, but no lights otherwise. Current: 2003 Range Rover Vogue SE Auto TD6, 2004 Mercedes C270 CDi Saloon Elegance SE
