Home > In Car Electronics (L322) > HK logic 7... to HD ?
Page 2 of 5 <12345>
muppet
United Kingdom 2012 Range Rover Westminster 4.4 V8 Barolo Black
Don't know if this helps at all....
 I need more help than most...sorry !!
Post #442061 20th Jun 2017 6:23am
GGDR
My build sheet showed the 1200w premium audio but then I realised there was a simple way to tell which one you've got.
. Cheers, Greg
Post #442107 20th Jun 2017 3:05pm
TOF
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Stornoway Grey
Thanks for the replies. The diagram that Muppet put up is a nice read. The sound on dvd through logic 7 is really good. I might try get a dolby pro ligoc music cd and see how that sounds.. normal audio through logic 7 is definitely lacking the sub bass.
Post #442144 20th Jun 2017 7:43pm
mjdronfield
Logic 7 is definitely best off for listening to music.
The pic Muppet posted is for Logic 7 on the early BMW based cars. It was an Autobiography option, before they made it an actual model.
http://www.fullfatrr.com/gallery/albums/us...0Rover.pdf
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #442146 20th Jun 2017 7:55pm
mjdronfield
So who knows the part number of the 1200w HD amp? 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #442481 23rd Jun 2017 8:39pm
GGDR
I can have a look at mine, where is it?
. Cheers, Greg
Post #442506 24th Jun 2017 4:58am
mjdronfield
Ah.... it's pretty buried in the boot and not easy to get to, so might not be poss to just have an easy look.
I was gonna search for amp online that was all.... not easy to ensure it's an HD one without confirming part numbers.
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #442518 24th Jun 2017 7:17am
GGDR
Are one of those three units the amp? The three with the heavy black line? If so do I need to get to the back so see the ID sticker?
. Cheers, Greg
Post #442528 24th Jun 2017 9:32am
nino_nino
mjdronfield,
this is the amp. I have. HK Logic7 HD.
Post #442571 24th Jun 2017 3:07pm
mjdronfield
Brilliant - many thanks.
I shall see what prices they go for....
I hope the connectors are the same.... will need to check a wiring diagram too....
Cheers
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #442574 24th Jun 2017 3:23pm
nino_nino
http://www.ebay.co.uk/itm/2010-2011-2012-R...rmvSB=true
Post #442575 24th Jun 2017 3:28pm
mjdronfield
So... about £230 on the bay of e.....
Need to know if the connection is the same and it doesn't need coding to the car now....
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #442576 24th Jun 2017 3:40pm
mjdronfield
Had a quick search, and as I can only see one diagram for the Logic 7 amps, I'd say that the wiring is the same, so you should be able to swap the amp for the HD one....
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #442584 24th Jun 2017 4:17pm
nino_nino
This is my setup, i don't do IPhone so the only dicente signal is from CD. USB and bluetooth are only mp3's (don't like),
samsung tab S10.5 and fiio Q1 playing via aux. most of my music is SACD rips .iso files played back native 1bit. now with logic 7 HD you get a real musical treat. Player is HibyMusic, excelente piece of software and free(google play).
my custom made Tab holder,
tablet is also excellent for navigation, I am using HERE. Thumbs Up
Post #442587 24th Jun 2017 5:12pm
mjdronfield
Right, will buy the HD amp, but I need to be fully sure its the right one..... is there any way to tell from pics between the standard Logic 7 and Logic 7 HD?
Do we know part number for standard unit, so I can avoid it?
Thanks
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #449000 24th Aug 2017 8:53pm
Page 2 of 5 <12345>
