Home > In Car Electronics (L322) > HK logic 7... to HD ? |
muppet Member Since: 09 Nov 2016 Location: manchester Posts: 90 |
Don't know if this helps at all....
20th Jun 2017 6:23am |
TOF Member Since: 13 Mar 2013 Location: Gloucestershire Posts: 53 |
Thanks for the replies. The diagram that Muppet put up is a nice read. The sound on dvd through logic 7 is really good. I might try get a dolby pro ligoc music cd and see how that sounds.. normal audio through logic 7 is definitely lacking the sub bass. |
20th Jun 2017 7:43pm |
Logic 7 is definitely best off for listening to music.
20th Jun 2017 7:55pm |
So who knows the part number of the 1200w HD amp? 2011 Range Rover Vogue SE 4.4 TDV8
23rd Jun 2017 8:39pm |
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3542 |
I can have a look at mine, where is it?
24th Jun 2017 4:58am |
Ah.... it's pretty buried in the boot and not easy to get to, so might not be poss to just have an easy look.
24th Jun 2017 7:17am |
Are one of those three units the amp? The three with the heavy black line? If so do I need to get to the back so see the ID sticker?
24th Jun 2017 9:32am |
nino_nino Member Since: 29 Mar 2015 Location: pocitelj Posts: 690 |
mjdronfield,
24th Jun 2017 3:07pm |
Brilliant - many thanks.
24th Jun 2017 3:23pm |
24th Jun 2017 3:28pm |
So... about £230 on the bay of e.....
24th Jun 2017 3:40pm |
Had a quick search, and as I can only see one diagram for the Logic 7 amps, I'd say that the wiring is the same, so you should be able to swap the amp for the HD one....
24th Jun 2017 4:17pm |
This is my setup, i don't do IPhone so the only dicente signal is from CD. USB and bluetooth are only mp3's (don't like),
24th Jun 2017 5:12pm |
Right, will buy the HD amp, but I need to be fully sure its the right one..... is there any way to tell from pics between the standard Logic 7 and Logic 7 HD?
24th Aug 2017 8:53pm |
