![]() | Home > In Car Electronics (L322) > HK logic 7... to HD ? |
muppet Member Since: 09 Nov 2016 Location: manchester Posts: 90 ![]() ![]() ![]() |
Don't know if this helps at all....
TOF Member Since: 13 Mar 2013 Location: Gloucestershire Posts: 53 ![]() ![]() ![]() |
Thanks for the replies. The diagram that Muppet put up is a nice read. The sound on dvd through logic 7 is really good. I might try get a dolby pro ligoc music cd and see how that sounds.. normal audio through logic 7 is definitely lacking the sub bass. |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7861 ![]() ![]() ![]() |
Logic 7 is definitely best off for listening to music.
So who knows the part number of the 1200w HD amp? 2011 Range Rover Vogue SE 4.4 TDV8
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3550 ![]() ![]() ![]() |
I can have a look at mine, where is it?
Ah.... it's pretty buried in the boot and not easy to get to, so might not be poss to just have an easy look.
Are one of those three units the amp? The three with the heavy black line? If so do I need to get to the back so see the ID sticker?
nino_nino Member Since: 29 Mar 2015 Location: pocitelj Posts: 690 ![]() ![]() ![]() |
mjdronfield,
Brilliant - many thanks.
So... about £230 on the bay of e.....
Had a quick search, and as I can only see one diagram for the Logic 7 amps, I'd say that the wiring is the same, so you should be able to swap the amp for the HD one....
This is my setup, i don't do IPhone so the only dicente signal is from CD. USB and bluetooth are only mp3's (don't like),
Right, will buy the HD amp, but I need to be fully sure its the right one..... is there any way to tell from pics between the standard Logic 7 and Logic 7 HD?
