![]() | Home > In Car Electronics (L322) > HK logic 7... to HD ? |
Roystonh Member Since: 21 Nov 2011 Location: Kent Posts: 395 ![]() ![]() |
I've got a 2011 AB and not really noticed a difference - will inspect the speakers tomorrow for you 2005 L322 Vogue Gold gone
TOF Member Since: 13 Mar 2013 Location: Gloucestershire Posts: 53 ![]() ![]() ![]() |
Thanks |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7893 ![]() ![]() ![]() |
1200w on the HD system....
I'm guessing then, possibly just the amplifier. I did read somewhere that the HD system had a 1200w class D amplifier. Not sure what amp the standard logic 7 system comes with, but i cant see them changing all the speakers for different ones... |
Ah... quite a few different speakers and looks like more of them...
Though I can't see where the extra speakers are....
Here, it gives more spec info, inc about a D class amp as you mentioned.
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3551 ![]() ![]() ![]() |
I think it was an option an all models. Maybe std on Autobiography. Mine is a Vogue SE and I was lucky enough to land it with the HD 1200w.
So, perhaps changing the 4 speakers from one way to the two way versions and upgrading the amp to the 1200 watt class d might do the trick then...
I turned the Logic 7 bit off on mine and it's much better. Sound comes out the door speakers lol.
My 2011 AB is just logic 7 not HD so must have been an option that year 2005 L322 Vogue Gold gone
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8740 ![]() ![]() ![]() |
There is the overiding question of, why??
I like my Barry Manilow to sound the best it can be...
We need to line two up for a side-by-side sound off! Cheers, Greg
