Home > Technical (L322) > Pulling off in first gear (TDV8 4.4) 2011 |
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3545 |
I've wondered the same - but how do you know what gear it's in?
31st May 2017 9:16pm |
TOF Member Since: 13 Mar 2013 Location: Gloucestershire Posts: 53 |
I have counted what seems like the gear changes, then pulled the paddle shift and it is never on the gear that i am expecting... |
31st May 2017 9:28pm |
I wonder if the ID tool could change the display?
31st May 2017 9:37pm |
I also do a bit of flappy action - mainly downchanges.
31st May 2017 9:39pm |
proser Member Since: 20 Jul 2015 Location: Stafford Posts: 452 |
after a period of time with no manual changes it goes back to normal D mode. Regards
31st May 2017 9:47pm |
Freddie The Fish Member Since: 13 Apr 2017 Location: Bedfordshire Posts: 115 |
Pull and hold the up paddle. |
31st May 2017 10:09pm |
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2529 |
Cancelling manual mode by holding the up-shift tab works for me as I almost only ever up-shift but if down-shifting then swapping to sport mode momentarily is the only viable method due to the lack of a specific button. |
1st Jun 2017 12:20am |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7831 |
Yea - cos it sometimes is a bit asleep when I suddenly want to overtake and pressing the throttle doesn't always result in a fast enough getaway I have to us paddles. You do thepass, come off the throttle and it stays in the lower gear... you want it to change up so you use the up paddle, so the timer starts again for it to go back into D. Pain in the bum. End us going S then D as others said.... 2011 Range Rover Vogue SE 4.4 TDV8
1st Jun 2017 5:25am |
Just hold the up-shift paddle for a couple of seconds longer after a manual up-shift to resume full auto mode. |
1st Jun 2017 7:34am |
ajac8 Member Since: 04 Oct 2011 Location: Shakespeares County Posts: 1661 |
Are you convinced this is a gearbox issue? 405 AB exec seats Baltic and Cirrus 93 RR Classic efi Remember it's easier to get forgiveness than permission! Gone in order: 4.4 TDV8 SE - gone to a good home 93 Classic hard dash Plymouth Blue 03 L322 Oslo Blue 2000 Disco TD5 ES Epsom Green 98 P38 Rioja Red 89 Classic Cairngorm Brown |
2nd Jun 2017 5:17pm |
Not sure if it is an issue... but also not sure it is normal... |
2nd Jun 2017 6:17pm |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3780 |
In answer to TOF's opening question.
2nd Jun 2017 6:30pm |
Maybe with the IDTool? I don't have one but it would be interesting. And massive thanks to Freddie the Fish - have tried the up and hold technique it's great! Have been downshifting manually then a long hold on the upshift paddle which gives me one manual upshift then back into D. All with one long hold! It's GREAT!!! Works really well and solves a little bug of mine with this otherwise fantastic gearbox. It's gone from almost the perfect manual & auto combination to the perfect combination!! . Cheers, Greg - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - 2011 Vogue SE 4.4 with lots of toys in Stornaway |
3rd Jun 2017 2:26pm |
Not tried it yet, but I did read the manual and it is in there. Not like me to miss stuff like that.
3rd Jun 2017 3:23pm |
