Home > Technical (L322) > Pulling off in first gear (TDV8 4.4) 2011
TOF
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Stornoway Grey
When i pull off from stand still, the revs go up, then drop a bit, then go up, then drop a bit (almost like it is changing gear very quickly, but it isn't) then it changes to 2nd, 3rd, 4th etc absolutely fine... is this normal...
Post #440271 31st May 2017 7:37pm
GGDR
I've wondered the same - but how do you know what gear it's in?
Mine only shows D unless you use the flappy... Then D1 D2 D3 etc.
. Cheers, Greg
Post #440284 31st May 2017 9:16pm
TOF
I have counted what seems like the gear changes, then pulled the paddle shift and it is never on the gear that i am expecting...
Post #440287 31st May 2017 9:28pm
GGDR
I wonder if the ID tool could change the display?
I think it IS going up through the gears... Cheers, Greg
Post #440290 31st May 2017 9:37pm
GGDR
I also do a bit of flappy action - mainly downchanges.
But does anyone know how to cancel and get back to 'normal' D mode.
Once I've flappy'd a bit I am flicking the knob to S then back to D but there must be a better way...?
. Cheers, Greg
Post #440291 31st May 2017 9:39pm
proser
after a period of time with no manual changes it goes back to normal D mode. Regards
Mark
2012 Westminster
GONE - 2007 Java Black FF Vogue, with Ivory interior
Post #440292 31st May 2017 9:47pm
Freddie The Fish
United Kingdom 2011 Range Rover SE 4.4 V8 Fuji White
Pull and hold the up paddle.
Post #440295 31st May 2017 10:09pm
GraemeS
Cancelling manual mode by holding the up-shift tab works for me as I almost only ever up-shift but if down-shifting then swapping to sport mode momentarily is the only viable method due to the lack of a specific button.
Post #440299 1st Jun 2017 12:20am
mjdronfield
Yea - cos it sometimes is a bit asleep when I suddenly want to overtake and pressing the throttle doesn't always result in a fast enough getaway I have to us paddles. You do thepass, come off the throttle and it stays in the lower gear... you want it to change up so you use the up paddle, so the timer starts again for it to go back into D. Pain in the bum. End us going S then D as others said.... 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #440305 1st Jun 2017 5:25am
GraemeS
Just hold the up-shift paddle for a couple of seconds longer after a manual up-shift to resume full auto mode.
Post #440307 1st Jun 2017 7:34am
ajac8
United Kingdom 2013 Range Rover Autobiography SDV8 Baltic Blue
Re: Pulling off in first gear (TDV8 4.4) 2011
Are you convinced this is a gearbox issue? 405 AB exec seats Baltic and Cirrus
93 RR Classic efi
Remember it's easier to get forgiveness than permission!
Gone in order:
4.4 TDV8 SE - gone to a good home
93 Classic hard dash Plymouth Blue
03 L322 Oslo Blue
2000 Disco TD5 ES Epsom Green
98 P38 Rioja Red
89 Classic Cairngorm Brown
Post #440462 2nd Jun 2017 5:17pm
TOF
Not sure if it is an issue... but also not sure it is normal...
Post #440471 2nd Jun 2017 6:17pm
Baltic Blue
In answer to TOF's opening question.
Yes, I think it sounds exactly like mine.
The engine seems very free revving on initial standing start, but very quickly settles to little more than tick- over revs until the speed builds up and gets into higher gear.
I agree it would be nice if the display showed D1, D2, D3 etc, rather than just D. G reg 2.5VM Vogue Portofino red 1991- 1999
Post #440472 2nd Jun 2017 6:30pm
GGDR
Maybe with the IDTool? I don't have one but it would be interesting.
And massive thanks to Freddie the Fish - have tried the up and hold technique it's great!
Have been downshifting manually then a long hold on the upshift paddle which gives me one manual upshift then back into D. All with one long hold! It's GREAT!!!
Works really well and solves a little bug of mine with this otherwise fantastic gearbox. It's gone from almost the perfect manual & auto combination to the perfect combination!!
. Cheers, Greg
Post #440525 3rd Jun 2017 2:26pm
mjdronfield
Not tried it yet, but I did read the manual and it is in there. Not like me to miss stuff like that.
Cheers
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #440527 3rd Jun 2017 3:23pm
