![]() | Home > Technical (L322) > Towbar newbie question - Westfalia 323051 |
CS Member Since: 14 Apr 2015 Location: Edinburgh Posts: 1401 ![]() ![]() ![]() |
I'd only use the proper item, the safety implications of getting this wrong are too severe.
rik Member Since: 21 Jan 2015 Location: argyll Posts: 265 ![]() ![]() ![]() |
another thought swan neck locks on to receiver with key and key will not come out unless located properly. so do not tow with key in lock I have towed 2 tonne caravan on holidays for a number of years with no incidents or worries . |
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3661 ![]() ![]() |
The Swan neck tow balls are different depending on which car they were designed for... not all the receivers end up at the same height, so they compensate for this with the swan neck part... Also the receivers don't all end up the same distance from the bumper, so the spacing differs too... And finally most Swan neck setups for normal saloon cars and are only rated at 2 tons, so there is every chance that the whole thing is smaller than a Range Rovers setup.
buffalo4 Member Since: 01 May 2016 Location: Doncaster Posts: 143 ![]() ![]() |
Is an alko ball necessary with the adjustable height hitch ? Thanks |
have you got air suspension? I am not sure what happens when you are driving or whether ride height is adjusted before it locks off but mine tows superb with swan neck ride height is never an issue |
Lukie Member Since: 27 Sep 2016 Location: Liverpool Posts: 433 ![]() ![]() |
all the tow bar have diffeent angles, locking systems and weight rating, you need the range rover one, I would also remove your 13 pin to 7 pin converter, you may find rear fog light's don't work with convertor fitted |
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3551 ![]() ![]() ![]() |
Don't know, never towed! Did you know, according to the manual you can adjust the ride height with the key fob. So long as the hazards are on.
Thanks great shout - I'll take it out tonight! Cheers, Greg - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - 2011 Vogue SE 4.4 with lots of toys in Stornaway |
That is a function of the trailer electrics, when the ECU detects a load on the trailer wiring it locks the ride height and changes the gear selection pattern, it is nothing to do with what towbar is fitted ![]() Inventor of the 'Guide-o-Matic automatic wheel alignment tool' Former long term L322 owner, Up/Down graded to a Classic Tractor! |
Keith A Member Since: 25 Oct 2012 Location: Sherborne, Dorset Posts: 105 ![]() ![]() ![]() |
I side-by-sided the westfalia swan neck on the BMW and RR. The BMW had a longer design (by about 1 inch). The connectors were the same, however the the design/robustness was a little different. The RR one had a thicker portion on the upper edge of the bar. Current cars:
Do you know how many kgs your BMW one is Keith?
Bud the only swan neck that will work with a Range Rover is a Range Rover swan neck, They are vehicle specific and type approved, if you were to suffer an accident towing with a swan neck from another vehicle there is a chance you could fall fowl of the insurance.... Also Vosa can check things like towbars, and towbar height....
that's an interesting one adjusting ride height with key fob must try that . makes you wonder why you would need that |
It's only rated for 2200kgs. Current cars: 09MY TDV8 Vogue SE Mini R56 Cooper S Mini Cooper Race Car ![]() |
