Home > Technical (L322) > Towbar newbie question - Westfalia 323051
Page 2 of 3 <123>
Hmm.
There's a question.
Possibly but it's not a good idea. The Ffrr is designed for 3.5 tonnes (more actually but for the uk 3.5t) and 150kg nose weight. Which is what the ball is designed to carry/pull.
Not much else is designed with these figures in mind so I wouldn't chance it. There is nothing that can't be fixed with a hammer😜😜
Post #437113 4th May 2017 10:12pm
CS
I'd only use the proper item, the safety implications of getting this wrong are too severe.
There should be a red plastic insert (on right in picture) that goes in the end of the receiver when the swan neck is detached. The swan neck won't lock in place properly if the inside of the receiver is dirty and the insert should keep it clean. If yours has run for a while without, it is probably worth cleaning the inside and checking that the swan neck is locking in place properly once that has been done. Only Range Rovers since 1988
Post #437153 5th May 2017 11:30am
rik
Scotland 2003 Range Rover Vogue 4.4 V8 Bonatti Grey
another thought swan neck locks on to receiver with key and key will not come out unless located properly. so do not tow with key in lock I have towed 2 tonne caravan on holidays for a number of years with no incidents or worries .
Post #437446 7th May 2017 10:56pm
miggit
The Swan neck tow balls are different depending on which car they were designed for... not all the receivers end up at the same height, so they compensate for this with the swan neck part... Also the receivers don't all end up the same distance from the bumper, so the spacing differs too... And finally most Swan neck setups for normal saloon cars and are only rated at 2 tons, so there is every chance that the whole thing is smaller than a Range Rovers setup.
If you want a cheap hitch then remove the Swan Neck receiver and fit a Farmers adjustable hitch... can be had for £95 new and normally around £50 S/H
 Yesterday I couldn't spell Engineer... Today I are one!
Post #437495 8th May 2017 11:38am
buffalo4
2009 Range Rover Vogue SE TDV8 Bournville
Is an alko ball necessary with the adjustable height hitch ? Thanks
Post #437496 8th May 2017 11:40am
miggit
Shocked Rolling Eyes AFAIK Alko is a manufacturer of trailer equipment, ans an "Alko ball" is a standard 50mm towball hitch, which is the EU standard, and every ones 50mm hitches are the same..
I had a Dixon Bate 5 ton combination hitch on mine... which is definitely something you cannot get if you're using the swan neck, you're stuck with towball coupling trailers, not the eye types Rolling Eyes Yesterday I couldn't spell Engineer... Today I are one!
Post #437499 8th May 2017 11:47am
rik
have you got air suspension? I am not sure what happens when you are driving or whether ride height is adjusted before it locks off but mine tows superb with swan neck ride height is never an issue
Post #437528 8th May 2017 2:54pm
Lukie
2002 Range Rover Vogue 4.4 V8 Zambezi Silver
gonna_go_double_r wrote:
Been looking on eBay. There are a few Westfalia swan necks there, does anyone know can I fit any old detachable neck?
There are ones for Audis, Ford Galaxys etc etc . Any towbar experts out there?
Thx!
all the tow bar have diffeent angles, locking systems and weight rating, you need the range rover one, I would also remove your 13 pin to 7 pin converter, you may find rear fog light's don't work with convertor fitted
Post #437531 8th May 2017 3:25pm
GGDR
Don't know, never towed! Did you know, according to the manual you can adjust the ride height with the key fob. So long as the hazards are on.
Thanks great shout - I'll take it out tonight! Cheers, Greg
Post #437535 8th May 2017 3:31pm
miggit
That is a function of the trailer electrics, when the ECU detects a load on the trailer wiring it locks the ride height and changes the gear selection pattern, it is nothing to do with what towbar is fitted Thumbs Up Yesterday I couldn't spell Engineer... Today I are one!
Post #437536 8th May 2017 3:32pm
Keith A
United Kingdom 2009 Range Rover Vogue SE TDV8 Buckingham Blue
I side-by-sided the westfalia swan neck on the BMW and RR. The BMW had a longer design (by about 1 inch). The connectors were the same, however the the design/robustness was a little different. The RR one had a thicker portion on the upper edge of the bar. Current cars:
09MY TDV8 Vogue SE
Mini R56 Cooper S
Mini Cooper Race Car Smile
Post #437643 9th May 2017 10:45am
GGDR
Do you know how many kgs your BMW one is Keith?
Thanks for checking too. Cheers, Greg
Post #437794 9th May 2017 11:02pm
miggit
Bud the only swan neck that will work with a Range Rover is a Range Rover swan neck, They are vehicle specific and type approved, if you were to suffer an accident towing with a swan neck from another vehicle there is a chance you could fall fowl of the insurance.... Also Vosa can check things like towbars, and towbar height....
And 90% of swan neck towbars are for 2 ton setups... they will not handle 3.5 tons...
There are 3 options
1, fit a swan neck and swallow the cost
2, fit the "farmers adjustable" hitch... which is easily removable, just pull the pin and it slides out, so you only have to see it when you're towing..
3, fit a totally different towbar, but be warned that the cheaper ones are fixed so you'll see the towbar all the time, and the ones that are removable are just as stupidly high priced. Yesterday I couldn't spell Engineer... Today I are one!
Post #437818 10th May 2017 8:29am
rik
that's an interesting one adjusting ride height with key fob must try that . makes you wonder why you would need that
Post #437880 10th May 2017 2:57pm
Keith A
It's only rated for 2200kgs. Current cars:
09MY TDV8 Vogue SE
Mini R56 Cooper S
Post #437883 10th May 2017 3:21pm
Page 2 of 3 <123>
