Home > Technical (L322) > Towbar newbie question - Westfalia 323051 |
CS Member Since: 14 Apr 2015 Location: Edinburgh Posts: 1373 |
I'd only use the proper item, the safety implications of getting this wrong are too severe.
5th May 2017 11:30am |
rik Member Since: 21 Jan 2015 Location: argyll Posts: 265 |
another thought swan neck locks on to receiver with key and key will not come out unless located properly. so do not tow with key in lock I have towed 2 tonne caravan on holidays for a number of years with no incidents or worries . |
7th May 2017 10:56pm |
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3657 |
The Swan neck tow balls are different depending on which car they were designed for... not all the receivers end up at the same height, so they compensate for this with the swan neck part... Also the receivers don't all end up the same distance from the bumper, so the spacing differs too... And finally most Swan neck setups for normal saloon cars and are only rated at 2 tons, so there is every chance that the whole thing is smaller than a Range Rovers setup.
8th May 2017 11:38am |
buffalo4 Member Since: 01 May 2016 Location: Doncaster Posts: 143 |
Is an alko ball necessary with the adjustable height hitch ? Thanks |
8th May 2017 11:40am |
AFAIK Alko is a manufacturer of trailer equipment, ans an "Alko ball" is a standard 50mm towball hitch, which is the EU standard, and every ones 50mm hitches are the same..
8th May 2017 11:47am |
have you got air suspension? I am not sure what happens when you are driving or whether ride height is adjusted before it locks off but mine tows superb with swan neck ride height is never an issue |
8th May 2017 2:54pm |
Lukie Member Since: 27 Sep 2016 Location: Liverpool Posts: 433 |
all the tow bar have diffeent angles, locking systems and weight rating, you need the range rover one, I would also remove your 13 pin to 7 pin converter, you may find rear fog light's don't work with convertor fitted |
8th May 2017 3:25pm |
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3542 |
Don't know, never towed! Did you know, according to the manual you can adjust the ride height with the key fob. So long as the hazards are on.
Thanks great shout - I'll take it out tonight! Cheers, Greg - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - 2011 Vogue SE 4.4 with lots of toys in Stornaway |
8th May 2017 3:31pm |
That is a function of the trailer electrics, when the ECU detects a load on the trailer wiring it locks the ride height and changes the gear selection pattern, it is nothing to do with what towbar is fitted Yesterday I couldn't spell Engineer... Today I are one! Inventor of the 'Guide-o-Matic automatic wheel alignment tool' Former long term L322 owner, Up/Down graded to a Classic Tractor! |
8th May 2017 3:32pm |
Keith A Member Since: 25 Oct 2012 Location: Sherborne, Dorset Posts: 105 |
I side-by-sided the westfalia swan neck on the BMW and RR. The BMW had a longer design (by about 1 inch). The connectors were the same, however the the design/robustness was a little different. The RR one had a thicker portion on the upper edge of the bar. Current cars:
9th May 2017 10:45am |
Do you know how many kgs your BMW one is Keith?
9th May 2017 11:02pm |
Bud the only swan neck that will work with a Range Rover is a Range Rover swan neck, They are vehicle specific and type approved, if you were to suffer an accident towing with a swan neck from another vehicle there is a chance you could fall fowl of the insurance.... Also Vosa can check things like towbars, and towbar height....
10th May 2017 8:29am |
that's an interesting one adjusting ride height with key fob must try that . makes you wonder why you would need that |
10th May 2017 2:57pm |
It's only rated for 2200kgs. Current cars: 09MY TDV8 Vogue SE Mini R56 Cooper S Mini Cooper Race Car |
10th May 2017 3:21pm |
